what size spacers do i need
Old Jun 21, 2006 | 10:06 PM
84c4vette's Avatar
84c4vette
Default what size spacers do i need
how do i figure out the offset for the spacers i have 00-02 camaro z28 rims on my 84 and they sit in maybe an inch and a half to much but i dunno what size spacers to get any help would be appreciated
Old Jun 21, 2006 | 10:31 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Old Jun 22, 2006 | 02:07 AM
84c4vette's Avatar
84c4vette
i know but how do i know what ones will fit my car? will any five bolt pattern work?
Old Jun 22, 2006 | 02:10 AM
goldeneye_vet's Avatar
goldeneye_vet
Type in corvette wheel adapter at ebay or follow the link below. You're looking for 5 x 4.75 spacing and you'll need a 1.5" adapter.
http://search.ebay.com/search/search...ter&category0=
Old Jun 22, 2006 | 09:12 AM
c4cruiser's Avatar
c4cruiser
The key word is "adapter" and not "spacer" Adapters bolt to the hub using the stock studs and the adapter has a separate set of studs for wheel attachment. Many adapters use a conical lugnut that will stick out beyond the adapter mounting flange on the whee side. OEM wheels usually have a recess in the wheel flange that will allow you to use these conical nuts.
If the wheels you are using have a flat mounting surface, (no recesses) than the adapter cannot have anything sticking out beyond the adapter mounting flange.
To what size spacers do i need
