1986 C4 Routine Maintenance Schedule
Old Jun 24, 2006 | 02:00 AM
Brian86's Avatar
Brian86
Default 1986 C4 Routine Maintenance Schedule
Can someone post one here?
I use to have one from http://www.c4vettes.com/
But looks like that site is gone now.
Old Jun 24, 2006 | 02:01 AM
bogus's Avatar
bogus
everything all the time.
Old Jun 27, 2006 | 06:10 PM
Brian86's Avatar
Brian86
Default Ok, I'll start the list.
1. Fuel filter
2. PCV Valve
3. Radiator cap
Old Jun 27, 2006 | 07:09 PM
vader86's Avatar
vader86
oil-3k if dino, filter as well
fuel filter-2 years, at every tuneup
plugs/wires/cap/rotor-2 years, and check the base timing setting
transmission-30k
rear axle fluid-100k
brake fluid-2 years, more if you race it
radiator flush-2 years, replace cap at same time
PS fluid-couple years, maybe longer if its not turned black
you'll probably end up replacing the battery once every 5 years or so
I never replace the PCV, but I do check that its still working.
basically it comes down 'everything all the time'
Old Jun 29, 2006 | 08:25 PM
Brian86's Avatar
Brian86
transmission-30k
Do you prefer Synthetic oil for the rear axle, transmission?
Old Jun 29, 2006 | 08:48 PM
vader86's Avatar
vader86
synthetics everywhere for me
Old Sep 23, 2006 | 04:55 AM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
To 1986 C4 Routine Maintenance Schedule
