Vats Help!!
Old Jun 24, 2006 | 01:43 PM
Buttz's Avatar
Buttz
Default Vats Help!!
I fired up my car lastnight on jackstands and it ran fine, Ow I also had it on a charger cause the batt was dead. Well today I Took it off the stands and tried to fire it up with no relults. The batt is reading at 11.5 volts and its a optima so it should crank. Help Any ideas??
Old Jun 24, 2006 | 01:51 PM
RRT vette's Avatar
RRT vette
Did the engine turn over at all? Make sure the key chip doesn't have anything on it and wait about 6 minutes after you try, and try again.
Old Jun 24, 2006 | 02:04 PM
93*Corvette's Avatar
93*Corvette
Having 11.5 volts when measured with a multimeter means nothing. What a car needs is amperage. That's why you always look for the biggest battery that fits your car, along with checking what the cold crank amps are.
You need to check your load and not your voltage. Use a load checker like this one at Harbour Freight.
http://www.harborfreight.com/cpi/cta...emnumber=90636
Old Jun 24, 2006 | 02:10 PM
Buttz's Avatar
Buttz
Nope it didnt turn over
Old Jun 24, 2006 | 02:23 PM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
Take the battery out and have it load tested at Auto Zone or some other parts place
Id bet you have a bad battery
You know optimas dont last forever
Old Jun 24, 2006 | 02:51 PM
93*Corvette
Great advice, take the battery out and have Autozone or Checkers do a load test...
Old Jun 24, 2006 | 06:55 PM
C6Nut400's Avatar
C6Nut400
what could that vats do? My volts always read 11.5 but it starts up without a hitch.
Old Jun 24, 2006 | 06:59 PM
HG's Avatar
HG
Quick check for the battery. Turn on the headlights, if they are nice and bright, try to start the car. If they dim or go out, it's the battery. If the VATS had it off, it would / should start in about 10 to 15 min for sure. Your amp seem low, they should be high 13 or 14 most of the time
Old Jun 24, 2006 | 09:07 PM
jfb's Avatar
jfb
You have a dead battery or a bad cable connection to the battery. Lead acid batteries are considered dead when the no load battery terminal voltage is at 12.0 volts or below. That you charged the battery and the terminal voltage is not above 12.0 volts tells me that you have a battery at the end of its life, or you have a poor battery cable connection to the battery terminals which I doubt.
To Vats Help!!
