remove adhesive from leather?
Old Jun 25, 2006 | 12:46 PM
POPA-VT's Avatar
POPA-VT
Default remove adhesive from leather?
What can I use to remove some adhesive from my leather arm rest door without discoloring the black leather. It's the adhesive that comes on those velcro strips.
Thanks in advance.
Old Jun 25, 2006 | 12:56 PM
Pete K's Avatar
Pete K
Zippo lighter fluid is my solvent of choice.
Old Jun 25, 2006 | 03:25 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
TWO extreams to try:
1) cloth wash cloth. Run it under some really hot water and see if you can gently rub the adheasive off onto the washcloth.
2) Ice it down with direct application of ice cubes abd then rub with cloth.
Old Jun 25, 2006 | 03:46 PM
Aquaman92's Avatar
Aquaman92
Goo be gone will take it off but It might discolor the leather.
Old Jun 25, 2006 | 04:18 PM
Jet-Jock's Avatar
Jet-Jock
How much is on there? Just a little try using a piece of other tape, use its sticky to remove the other sticky.
You could try alcohol on a cloth and wipe it. Really bad, 3M Adhesive Cleaner on a rag and wipe it off. I wouldn't apply anything directly to the leather.
Old Jun 25, 2006 | 07:42 PM
POPA-VT's Avatar
POPA-VT
I used Goof Off and had no problem. Didn't discolor at all.
Thanks for all the ideas
To remove adhesive from leather?
