Are these worth the money. The regular ones are ten bucks a piece, these are $32.00. I don't use them much so I don't think they will wear out the motor and gears. Opinions .
They came from the factory in my 96. It has 116,000+ miles on it with lots of headlight use. Never had a problem with the headlight doors.
I just put in new hinge pivot bushings and now it looks like I need new gear bushings. Wonder if this is the prob. My passenger side had the light weight light and was fine. The driver side had the regular light and needs the bushings, hmmmmmmm.
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
This is one of the first things Gordon Killebrew tells you to do in his class on C4s. You can buy them at NAPA for a WHOLE lot less than what you were quoted!
I have never heard of this. Light Weight headlights? If I go to NAPA is there a part number, or do I just say I want Light Weight headlights for my C-4? Just wondering if the guy behind the counter would look at me like I am a dumb-azz for asking. Also, how can I tell if I already have them? No point in replacing them if they are already there.
I got mine at Ecklers. The first time the right original went out. So I trucked down to the local parts store and got replacements (glass). When I was installing them I noticed how much heavier they were. A couple months later my right headlamp motor (post bushing replace) when to headlight motor heaven. So after $285 for a new motor, I bought a set of the lightweight plastic one's and have had no problems since.
I can't say for certain the heavy lamps blew the cam off the sprocket, but something sure caused it. But it's a awful coincidence.
My advise unless your changing to the exotic technology lamps stay with the plastic lightweigh lamps. Save your motors the extra work.
I dont want to question Gordon Killebrew's wisdom, but headlights that light the road properly (stock ones dont) should be your first priority.
My suggestion is to buy Bosch or CIBIE European E-Spec reflectors, 100/130 watt Narva clear bulbs, rewire the headlamp wiring with 10 gauge wiring and relays to limit resistance.
The parts will cost you about $200 and you will be able to see the road for 120 MPH nighttime jaunts.
I got my parts thru Daniel Stern lighting (do an internet search. he knows what you need).
I've had problems with my headlights since I got them. I can tell you what you should NOT do. Dont buy the heavy duty bronze gears for '84-'87 headlights. They weigh a ton and will kill your motor.
The potential problem with that is people often fail to realize the impact they're having on oncoming traffic when they put aircraft landing lights on their car so they can see better. There are laws for how bright and what color headlights are to be for a reason. Just something to keep in mind.
That is the beauty of E-spec. DO some research on them.
Low-beams have a cut out in the path of oncoming traffic. High beams are *****-out-max lighting-I-dont-care-who-I-am-going-to blind.
Also, I discourage the use of silly, toy, tinted-blue, HID-simulator bulbs. The yellowish hue of a clear halogen bulb is the best for lighting (your eye is most sensitive the reflected yellow light) .
I also want to mention. A lower cost option is the sylvania silverstars. I havent used them, but ive heard good things from forum members.
Originally Posted by Mr Mojo
The plastic headlights started in 1995 and they light the road just fine in my car.
I don't have the 87 that I put those lights in but Gordon just said to ask for the 95-96 application. You can tell if they are plastic or not as soon as the counter person brings them to you.
Gordon looked at my new-to-me 96 and proclaimed that "You need to change these over to plastic units - it will save your motors."
Now, since I am just babysitting this car for the summer and will return it to Brandt this fall I hate to change his "obviously after-market" lights back to plastic without his permission.
The plastic units I put on the 87 were more than adequate.
My $.02
I put the "Diamond Cut" headlights that were on eBay. I guess they're plastic because they only weigh a few ounces each. They light the road up pretty well, but I don't see a big difference between low & high beam. I'm sure the light weight is helping with the gears and motors...so far all original.
My 94 came with the plastic units. When one burned out, I replaced it with a glass light. There was a big difference in how fast the lights flipped open. The glass one was considerably slower. I replaced the glass unit with a plastic one and after replacement, both lights open at the same speed. I was concerned that the extra weight would cause the motor to fail sooner.
The plastic unit was made by Wagner and came with a lifetime guarantee. I think I paid about $12, certainly no more than $19. I bought it at a local autoparts store that is no longer in business. It was a direct match to the other unit that came with the car. One of the other posts has the part number.
From: SCMR Rat Pack'r Charter Member..Great Bend KS
I have to agree.
The highly-esteemed Hella units are also a good choice. If you go with 90/100W H4's, you won't have to relay/rewire...and the lighting is far superior to the stock type 55/60W headlamps. As far as bulb brands go, try to stick with either Sylvania or Philips/Osram.
Plastic lights? I had them on my '96, but was not impressed with their light output. If you still want to use them, I have the units I took out (Wagner Halogen)...I think they are in the "pay it forward" stickie. Pay shipping and they are yours. ( I sent a pair of SilverStars to a CF member through that same thread, and the shipping was $13 as i recall )
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
I have a 93 and plastic headlamps. I believe this had to have been at least an option back in 93. I replaced my lights to add the HD bulbs and had to go glass. There is a huge difference in weight.
