Automatic Ratchet shifter
Old Aug 31, 2001 | 04:22 AM
nsimmons's Avatar
nsimmons
Default Automatic Ratchet shifter
Im looking for one that fits the stock console. Any ideas?
Old Aug 31, 2001 | 09:37 AM
Bob86ZZ4's Avatar
Bob86ZZ4
Default Re: Automatic Ratchet shifter (nsimmons)
I searched high and low for a shifter for the Corvette console. I don't think anybody makes one, at least not as of last fall. I put in a B&M Megashifter. It took a bit of work to make it fit. As you can see from this picture the boot does not reach down far enough. The shifter I put in is made for a 82-93 Firebird/Camaro console, I don't remember the exact model number. Something like 80698. I have taken the car to a guy that does custom street rod interior and he said he is going to make me a nice black leather boot that will fit real well. He said it will cost $50. I just have to take the car back to him and leave it for a couple hours so he can make it. The shifter handle looks kind of high in the picture but it is very well positioned for shifting and I like the position very much. If you decide to put one in e-mail me while you are doing it if you have any questions and I will call you and talk you through it if I can.
Old Aug 31, 2001 | 03:40 PM
Raysur's Avatar
Raysur
Default Re: Automatic Ratchet shifter (Bob86ZZ4)
Hurst is supposed to be making a Vmatic 2 for us auto guys. We just have to wait awhile.
Old Aug 31, 2001 | 04:26 PM
nsimmons's Avatar
nsimmons
what have you done about the lighted gear indicator? do you have any more pictures? i was thinking about maybe trying the quick silver..also does the t handle screw off? its it a normal threaded connection?
ok i took a closer look at the pic,i see you've used the camaro plate and bolted it to the console,that would take car of the gear selection. How about actually mounting the shifter? did it bolt right in? or did you have to drill?
[Modified by nsimmons, 2:27 PM 8/31/2001]
Old Sep 1, 2001 | 10:28 AM
Lloyd Smale's Avatar
Lloyd Smale
I have that exact shifter in my iroc it works great!! and it has its own lighted shift indicator
Old Sep 3, 2001 | 05:20 AM
nsimmons's Avatar
nsimmons
hey bob still around?
Old Oct 20, 2011 | 10:34 PM
c4nate's Avatar
c4nate
Hey Im new to the forum and I know that the thread Im referring to is old, but I was just wondering how did the shifter fit and look after you completed the installation. My brother bought me a 1985 c4 for graduation and Im wanting to do the same.
Old Oct 21, 2011 | 10:15 AM
Wildride's Avatar
Wildride
Cruise-In II Veteran
A possible DIY solution. I haven't tried it.
http://www.geocities.ws/jgkov/ShiftGate.html
http://www.geocities.ws/jgkov/ShifterPics.html
Old Oct 21, 2011 | 07:30 PM
c4nate's Avatar
c4nate
Old Oct 21, 2011 | 09:58 PM
84wannabezo6's Avatar
84wannabezo6
I have been looking for the black **** with the chrome button on top also I think the stock shifter was shortened
Old Oct 21, 2011 | 10:46 PM
avigar's Avatar
avigar
It would be very cool if Hurst made a dual gate shifter that would fit the C4. I had one on my '79 Z28.
Old Oct 21, 2011 | 11:21 PM
cv67's Avatar
cv67
St. Jude Donor '05
Do a thread search on mseven he did a super clean install on his looks about as factory as youll get
Old Oct 22, 2011 | 12:01 AM
oldalaskaman's Avatar
oldalaskaman
I did a stealth ratchet based on msevens and others threads. the after market shifter will actually fit in the current auto slot without having to leave it on top of the consol. you fabricate an aluminum plate, that bridges the tunnel in the floor , mount the shifter to that and then reinstall the consol, then just get any of the aftermarket boots. If you want to keep the indicator, you'll need to use the setup 'cover' that came with the shifter or make one . The stealth had indicator panel, reverse lockout , reverse microswitches, etc. any shifter will work as log as its adapable to the 700R4 and you are handy
Old Oct 22, 2011 | 02:29 AM
c4nate's Avatar
c4nate
A thread search on mseven?
Old Oct 22, 2011 | 07:55 AM
oldalaskaman
he's a member that posted the tech . with pictures, among others
Old Oct 22, 2011 | 10:08 AM
cv67's Avatar
cv67
St. Jude Donor '05
Go up towards the top of the page hit search type in the name then start browsing.
You can click on their name, "statistics" then threads started by XXXX
Here it is.
http://forums.corvetteforum.com/c4-t...s-to-date.html
Old Oct 22, 2011 | 11:56 AM
oldalaskaman
thats the one, very professional install
Old Oct 22, 2011 | 02:47 PM
c4nate's Avatar
c4nate
To Automatic Ratchet shifter
