Disassembling an Optispark
Old Jul 5, 2006 | 04:23 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Default Disassembling an Optispark
I want to disassemble my old Gen I optispark. I've already bought an E4 Torx socket from Snap-On to take out the 4 screws that hold the two halves together. Now I find I need a very small Torx driver to remove the two screws that hold the rotor in place. Does anyone know the size? I think its either T9 or T8.
thanks
Old Jul 5, 2006 | 05:50 PM
DG'sVette's Avatar
DG'sVette
I bought a little cheap set of torx drivers for about $3 at Homedepot.
Its a suggestion.
Old Jul 5, 2006 | 05:57 PM
jrzvette's Avatar
jrzvette
Its a suggestion.
So did I but the smallest size is T10, which is too big.
I know Snap-On has a T8, and Home Depost has a set of Torx Keys in a set that looks like a pocket knife. It has a T9. I just don't want to buy a lot of small ones because I don't think I'll have any other use for them.
Old Jul 5, 2006 | 06:15 PM
comp's Avatar
comp
they will get used sometime
To Disassembling an Optispark
