Help With Digital Dash...
Old Jul 10, 2006 | 02:44 AM
Dostovel's Avatar
Dostovel
Default Help With Digital Dash...
Sorry for the pic quality but you get the idea.... I jinx myself all the time... Well anyway, along with every other light going out on the Vette, add the dash to the list... along with the left side of the climate control and the top portion of the windshield washer control on the drivers side door panel, but the dash is more or less what I am curious about. As you can see it's dimmed on the right side and the tach looks to be loosing illumination as well... So is there a way to replace the bulbs that illuminate it or should I just buy new parts and is there even new parts I can buy? If so where should I look?
Old Jul 10, 2006 | 02:48 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
You have a bulb out. I'd recommend replacing all four. I think 88 is when they switched from 882 to the 194s. You can supposedly get to them by pulling the circular bulb covers off the front of the plastic cluster housing. So just remove the dash bezel first.
I've done it by dissecting the cluster, and that's a cluster**** you should try and avoid, because you risk damaging it.
Old Jul 10, 2006 | 04:06 AM
Dostovel's Avatar
Dostovel
Not to sound like a douche... but I have very little if not any mechanical skill... especially with interior stuff. I don't want to risk breaking or marking anything. Is there a shop that can do it...? :o
Old Jul 10, 2006 | 04:25 AM
86PACER's Avatar
86PACER
Definately a do it yourself job. You might not need to remove and take apart the cluster itself (kinda a pain in the azz). That will depend on weather or not the bulb holder where the bulbs are on is broken or not. If it is broken, you will need to remove the cluster, open it, seperate the two circuit boards, retreive the old broken one, and install a new bulb holder from the inside. If just the bulb is out and the holder (bulb base) in place, simply remove the cap and pull it out as mentioned above. Use pliers.
To get the plastic trim that's in front of the instrument cluster off, tilt down your steering wheel all the way. Then unscrew the tilt lever and remove it. If it's too tight by hand, there is a provision for a small wrench on the inner end of it to turn it by.
Now remove the screws on the far left side of the dash where the door closes, and the ones along the front. Pull the trim cover off. This is what you should see. There is a bulb under each on of those caps. Turn your key to the "On" positon and see which ones are out.
Old Jul 10, 2006 | 05:13 AM
86PACER's Avatar
86PACER
Wiper/washer switch only has one bulb. I too thought it had two, because the top looked dimmer than the bottom. I took it off, and it had only one. Bulbs specs and wiring diagram confirm. Same switch used 84-89. So back on it went.
I'll share the bulb specs from my '86 Shop Manual untill you get a copy for your '88. Most of these might be the same on your '88, but don't quote me on that. There's several small changes throught the years. The bulb number is generally found on the bulb itself unless it's faded off.
If you turn out to have 194 bulbs insted of 882's in your cluster as mentioned above, you'll have a much higher chance of finding the 194 bulb at a local parts store than the 882. The 194 is the most common bulb used in the car. I've always been able to find this bulb at the local Kragen store. An 882 at the dealer is over $20 each. I only found it at Napa, $9 each. No one else had it locally.
Old Jul 10, 2006 | 08:49 AM
87vette's Avatar
87vette
I had this same problem last summer and had to change the bulbs. However I disagree with the guys saying you can pull the bulbs out from the front by removing the bulb covers though. The only way I could see this being done was if you just remove the bulb itself and not the socket. I had to take my dash apart just to be able to pull the socket out with the bulb because it wouldnt pull out from the front since it was too big. The reason I say this is because when I pulled the bulbs out from the front... they usually break. So for my peace of mind, I went in from the inside.
Old Jul 10, 2006 | 06:15 PM
86PACER's Avatar
86PACER
That's what I was implying. If only the bullb is bad you don't need to replace the holder unless it's broken, you can re-use the holder as it sits. That will save you from having to remove the cluster and taking it appart. The reason I had to go in from the inside was because my bulb holder was broken and fell inside. The second bulb I had out did have the holder in tact. I pulled that bulb out from the front using needle nose pliers. Gripped it just enough to hold it and not break it. I worked for me. I'd rather try to pull it and it break on me then take the cluster apart first. When trying to seperating the two circuit boards inside the cluster, it's easy to damage the cluster if you don't know what you are doing.
Old Jul 10, 2006 | 06:17 PM
topgunvette's Avatar
topgunvette
Old Jul 10, 2006 | 07:19 PM
87vette's Avatar
87vette
Originally Posted by vancityguy
my dash is always on the fritz too, lights go super bright and dark again... i usually don't care much though, i never look at my speed
Mine did that and I found out the cables to the battery were not fully seated. So I removed and the terminals. I had to tighten even more and now it stopped doing what you described.
Old Jul 10, 2006 | 07:21 PM
topgunvette
To Help With Digital Dash...
