no start after replacing fuel pump
Old Jul 12, 2006 | 11:06 PM
jamo4's Avatar
jamo4
Default no start after replacing fuel pump
My '89 began to stall at low speeds. After I replaced the fuel pump and filter the car would not start. I then replaced the fuel regulator and still will not start. The fuel pump comes on for 2 seconds when the ignition is on and is pumping over a half pint of gas at the manifold when energized for 15 seconds manually. The injectors are getting 12 vollts. when I put starting fluid in the intake manifold the engine will run for about 5 seconds. Seems there is not enough fuel pressure at the injectors. Please help, thank you.
Old Jul 12, 2006 | 11:15 PM
PAINTER MAN's Avatar
PAINTER MAN
I installed a fuel pump I bought from autozone. I wired it acording to the instructions. I should have looked at the one I took off closer. The instructions had the wiring backwards and the car wouldn"t run. I pulled one of the fuel lines at the pump an seen it wasn't pumping. I pulled it again and reversed the wires. The problem was solved. The instructions were wrong. It did run for two seconds priming the pump though, problem was it ran backwards.
Old Jul 13, 2006 | 07:26 AM
RRT vette's Avatar
RRT vette
This tells me that, somehow you know there is fuel at the fuel rail. When the key is initially turned to the on position, the fuel pump relay energizes the fuel pump. It will only do this for 2 sec. then shut off. You will need a fuel pressure guage attached to the schrader valve on the right hand side fuel rail. When the key is turned on, note the pressure reading. You can manually energize the fuel pump by connecting a jumper wire from the + side of the battery to terminal G on the ALDL. This will run the pump until removed. You can use a test light at the fuel pump fuse and at the connector above the fuel pump while powering terminal G.
Also as suggested, make sure the fuel pump connections are correct, make sure the filter was put on correct, and that the spring and diaphram are in right. If you can spray starting fluid into the intake and it run, then you have a fuel problem, as of now. You can push the schrader valve down and fuel should come out (under pressure), but you want know how much pressure is there without a fuel pressure guage. The oil pressure switch is a back up to the fuel pump relay and will start the engine when 4 psi has been met while cranking.
Try these few things and get back.
Old Jul 13, 2006 | 11:32 AM
rick lambert's Avatar
rick lambert
read your post in tech,check your injector fuses.
To no start after replacing fuel pump
