cold start Valve Assy - O-ring Help
Old Jul 15, 2006 | 03:14 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default cold start Valve Assy - O-ring Help
Hey guys,
87, L98/350/Tpi
had a leak at the back of the fuel rail, where the Cold Start Valve assy attaches to the fuel rail. Helms shows O-ring seal 104. Checked around at Chevy dealers and no luck here in WA, Did reach Superior, and they can order the set for me, but will be a week or so till i get it. Check Shucks, Napa, lowells, Depot, and no luck.
Anyone had to substitute the o-rings? or anyone have a spare in good shape that's available...
vinnies87
Old Jul 15, 2006 | 03:17 PM
Pete K's Avatar
Pete K
I used 2 small o-rings from a universal o-ring assortment. It worked fine.
Old Jul 15, 2006 | 03:24 PM
vinnies87's Avatar
vinnies87
Yea I hear ya... just got back from napa and picked up 2 pkgs of universal. When you did it, did you find that the seal around the tip or the OD fit to the rail was best...
Old Jul 15, 2006 | 03:43 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I believe this is the correct o-ring size, check here. If it turns out to be wrong, please correct me.
http://webpages.charter.net/khasting...uelsystem.html
Old Jul 15, 2006 | 03:51 PM
vinnies87's Avatar
vinnies87
Thanks a bunch bud, i'll keep on checking. Chris @ Superior called back and he found a complete set of the cold start o-ring kit, but still next week...
Old Jul 15, 2006 | 04:24 PM
Pete K's Avatar
Pete K
The rings I used had a snug fit inside the yube and had to be stretched over the nipple end.
Old Jul 15, 2006 | 06:28 PM
vinnies87's Avatar
vinnies87
Ended up doing the same thing. Pressure checked okay... so for now she's okay.
thanks for the info..
vinnie
To cold start Valve Assy - O-ring Help
