Build sheet ????
Old Jul 17, 2006 | 11:58 AM
9vette4's Avatar
9vette4
Default Build sheet ????
This may sound weird, but where are the build sheets located on vettes? I have a '94 coupe.
Old Jul 17, 2006 | 12:06 PM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
The RPO codes should be on the inside of the console lid or inside of the compartment behind the seat. The build sheet is on top of the gas tank I believe. You can order a new one from the NCM.
Old Jul 17, 2006 | 12:14 PM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
Gas tank and the front cross member of the frame.
Old Jul 17, 2006 | 12:16 PM
topgunvette's Avatar
topgunvette
Old Jul 17, 2006 | 12:17 PM
kalister1's Avatar
kalister1
Try a magnet?
Old Jul 17, 2006 | 12:51 PM
Jet-Jock's Avatar
Jet-Jock
Correct, Or... order a build sheet with a window sticker laminated from NCM.
Old Jul 17, 2006 | 03:16 PM
AILERON's Avatar
AILERON
Order the build sheet from the Museum and it'll be worth the extra bucks for the window sticker, also.
The original build sheets are probably gonna be too fragile to do any good. The one up front in the cross member was stuffed into a hole
and it's been subjected to a LOT of heat over the years.
The one on top of my tank, at least, was glued there, so if yours was also, that's just about useless.
Frame the new ones and hang them in the den. They make great conversation pieces.
Old Jul 17, 2006 | 03:18 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
i would just get a new one.
To Build sheet ????
