pull codes
Old Jul 20, 2006 | 01:19 PM
TOMSLT1's Avatar
TOMSLT1
4th Gear
Default pull codes
how to pull codes from a 95 lt1
Old Jul 20, 2006 | 01:23 PM
DG'sVette's Avatar
DG'sVette
Paper clip from pin 4 to 12.
Codes will read out on the speedo.
Old Jul 20, 2006 | 01:42 PM
RRT vette's Avatar
RRT vette
write down what you see and post it here.
Old Jul 20, 2006 | 03:19 PM
C6Nut400's Avatar
C6Nut400
how bout on an 86? Do this with just the battery on?
Old Jul 20, 2006 | 04:43 PM
RRT vette's Avatar
RRT vette
On a 86 use the paperclip in terminal A and B (top two far right... next to each other), turn the key to on and watch the SES light. It blinks instead of giving a number. Blinks a code 12 first, then what ever code is stored, then the code 12 again.
Old Jul 20, 2006 | 05:48 PM
C6Nut400's Avatar
C6Nut400
thank you! So the code to look for is in between the two code 12s?
Old Jul 20, 2006 | 06:51 PM
RRT vette's Avatar
RRT vette
The code 12 is a diagnostic check of the ECM and will show up evertime as long as the ECM is working properly. The code 12 will flash before and after any stored codes and this tells you that no more codes are present.
Old Jul 21, 2006 | 04:22 PM
C6Nut400's Avatar
C6Nut400
okay. And how many blinks= the code #?
To pull codes
