abbreviations list?
Jul 24, 2006 | 07:55 AM
abbreviations list?
Where is a list of abreviations so I can figure out what folks are talking about? What's a DIC, SES, CTS, CTV... Sorry for being dumb but I just need to see the real name at least once. Arlon
Jul 24, 2006 | 08:00 AM
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
DIC is the Driver Information Center. That's the info that lights up such as "Service Engine Soon" when you have a problem.
Others will chime in with more. Good question!
My favorite is LMFAO which means, Laugh My Freakin **** Off.
Jul 24, 2006 | 08:16 AM
Fortunately I'm only behind on the Corvette ones. My 85 LTD doesn't have half the abbreviations in it...
Jul 24, 2006 | 10:14 AM
CTS = Coolant Temperature Sensor. Sometimes called ECT (Engine Coolant Temp sensor)
Dunno about CTV. Don't recall ever seeing that one before
Others you will see here include:
ECM = Engine Control Module (computer -- became PCM in '94 when it also began to control shifting of auto trans)
KS = Knock Sensor
TPS = Throttle Position Sensor
MAF = Mass AirFlow sensor
MAP = Manifold Absolute Pressure sensor
VSS = Vehicle Speed Sensor
IAT = Inlet (or Intake) Air Temperature sensor
O2S = Oxygen Sensor
IP = Instrument Panel
EGR = Exhaust Gas Recirculation
AIR = Air Injection Reaction (or something close to that - system that pumps air into the exhaust manifolds to burn off leftover hydrocarbons)
There are plenty more, but these are what are coming to mind for me as I type. Does this help?
Be well,
SJW
Jul 24, 2006 | 10:31 AM
Hello
How about "ttt"?
MDred85
Jul 24, 2006 | 10:47 AM
Quote:
Originally Posted by MDred85
Hello
How about "ttt"?
MDred85
Take To Top.
Look at this site.
http://www.gaarde.org/acronyms/?lookup=A
Jul 24, 2006 | 11:33 AM
A couple more have come to mind:
VATS = Vehicle Anti-Theft System. Uses a resistor pellet in the ignition key.
PKE = Passive Keyless Entry.
Be well,
SJW
Jul 24, 2006 | 12:30 PM
SJW
I believe on later yr C4's it became UTD but I can't say for certain as I'm not as familiar with the early year models.
Universal Theft Deterrent
I mention this because looking up an issue with VATS in the FSM will not yield anything, however, UTD will.
FSM = Factory Service Manual.
Actually one needs to sit down with each major chapter in the FSM to pull out all the acronyms as each chapter has it's own set.
Jul 24, 2006 | 12:41 PM
Be well,
SJW
Helped enough that I just printed it off, and taped it to my monitor..
Didn't fix my idle issue but it sure helped me understand what some other people were posting about. Thanks. Arlon
Jul 24, 2006 | 01:14 PM
I always liked CRS - Can't remember Sh*t.
This is what I have everyday.
Take care, it will become easier as you go.
Jul 24, 2006 | 01:31 PM
And who could forget Good Morning, Vietnam :
Seeing as how the V.P. is such a V.I.P., shouldn't we keep the P.C. on the Q.T.? 'Cause if it leaks to the V.C. he could end up M.I.A., and then we'd all be put out in K.P.
Jul 24, 2006 | 02:47 PM
Hello
How about "ttt"?
In New Jersey, it stands for "Two Ton Tony".
Jul 24, 2006 | 03:21 PM
Here's one more:
IAC = Idle Air Control
Be well,
SJW
Jul 24, 2006 | 04:07 PM
C4 of Year Finalist (appearance mods) 2019
And of course the infamous LTPWS = Low Tire Pressure Warning System
IIRC = If I remember Correctly
Jul 24, 2006 | 05:01 PM
Quote:
Thanks!! I've been trying to figure that one out for a while. Of course I refused to ask for the answer.
Jul 24, 2006 | 05:30 PM
When it breaks, it's P.I.T.A. Pain In the A**
Jul 24, 2006 | 06:13 PM
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
These two I learned pretty quick in Special Forces, and they're certainly appropriate in a Corvette forum. The only difference here is that you have to fix the problem with your checkbook instead of calling in an airstrike or artillery.
FUBAR F#cked Up Beyond All Recognition
SNAFU Situation Normal, All F#cked Up
Jul 24, 2006 | 06:17 PM
Some of those just don't seem like sanctioned GM terms
Jul 25, 2006 | 09:56 AM
Jul 25, 2006 | 10:23 AM
St. Jude Donor '07
Quote:
Originally Posted by Arlon
what's an FPR?
Fuel Pressure Regulator
