Replacing outer door seals
Old Sep 4, 2001 | 05:13 PM
90rdstr's Avatar
90rdstr
Default Replacing outer door seals
The Tech Section gives a fast approach to replacing the outer window seals without removing the door panels. It mentions replacing the rivets with screws but does not give the screw size and length. Has anyone done this? What size screws did you use?
Old Sep 4, 2001 | 05:29 PM
FastZR1's Avatar
FastZR1
Veteran: Marine Corps
Default Re: Replacing outer door seals (90rdstr)
How can you drill the rivets out without removing the door panel?
Old Sep 4, 2001 | 06:50 PM
91-Z07Coupe's Avatar
91-Z07Coupe
Default Re: Replacing outer door seals (fastzr1)
Do like I did, take the door panels off and do it right. It's not difficult to remove them, just a few screws and they are off. Then it's much easier to get to the outer weatherstrips.
Old Sep 4, 2001 | 07:26 PM
Jason's Avatar
Jason
CI 4-5-6-7 Veteran
Default Re: Replacing outer door seals (91-Z07Coupe)
Just ordered mine today. Not really looking forward to this project, but I really need to replace them. :(
Old Sep 4, 2001 | 09:24 PM
1MoorTym's Avatar
1MoorTym
Go to Sears and buy a package of 3/16 x 1/4 Aluminum rivets. The heads match whats in there now and they lay flat enough to not interfere with the window operating and they will never rust.
To remove the old ones, use a sharp chisel and 'carefully' whack the heads off. This is a lot cleaner then trying to drill them out as you're never going to get all those filings out of the door.
Old Sep 4, 2001 | 09:27 PM
GlockLT4's Avatar
GlockLT4
Default Re: Replacing outer door seals (1MoorTym)
Yes, replace the rivets with rivets. You most likely won't be able to get the one by the mirror on though.. it should be fine though. I haven't had any problems thus far.
Old Sep 4, 2001 | 11:37 PM
CG77VETTE's Avatar
CG77VETTE
I replaced mine a few months ago and I agree that the panels should come off in order to do the job easier and right. Also, use rivets and not screws. If the screw heads are too large you will scratch the glass. The door panels come right off and are the easiest panels I have ever removed and reinstalled.
To Replacing outer door seals
