Lt1 V.s. L98???? Help!!!!
Old Jul 26, 2006 | 01:22 AM
drewk86's Avatar
drewk86
Default Lt1 V.s. L98???? Help!!!!
hey everyone i'm fairly new to the site and i really like it, it has a lot of good information. Well i will be buying a vette soon. (within the next few months). And from the looks of it i will be buying a c4. My question is which engine is better? I know that the Lt1 is newer but is it that much better than the l98 that i need to spend a few grand more to get one? Same issue for the quality of the car, is a newer c4 that much better than the older ones? The only one i haven driven was a 92 vert and i liked it really well, are the L98's any way comparable to the Lt1's.
Thanks, Drew
Old Jul 26, 2006 | 01:28 AM
cv67's Avatar
cv67
St. Jude Donor '05
L98s have a lower redline, they are done around 4800 . Feel great at lower revs, though, great reponse and part throttle snap.
Drive one of each
Old Jul 26, 2006 | 01:37 AM
1985 Corvette's Avatar
1985 Corvette
Can't really go wrong either way. L-98 Vettes are great starting Vettes. With the extra thousand(s) you didn't use to purchase the LT-1, you can use to as maintainence costs on the L-98 car. Just a suggestion. Unless you're spoiled by all the car mags that post 0-60 times in the 5's and below, the L-98 has enough low end grunt and power to get you up to speed nicely when you want to "get going".
Again, there is no wrong answer to your question.
Old Jul 26, 2006 | 01:52 AM
4REGT4's Avatar
4REGT4
As the others have said -- you will need to drive both to see what you prefer. The LT1 cars are better cars than L98 cars. I hate C5s (ugly -- don't feel like driving a race car etc.), but technically I must admit that those too are better cars than my 95... As far as power goes... The LT1 is more powerful, but neither the LT1 or L98 feel all that much slower (while legally driving on the street) than even a C5... At any rate -- this kind of thread always causes a feud... not to mention -- good luck with your search.
vader86's Avatar
vader86
always get the newest car you can afford
Old Jul 26, 2006 | 02:10 AM
4REGT4's Avatar
4REGT4
I agree and disagree. The bottom line is that you must expect problems to arise with an older sports car and plan on doing a lot of the work yourself (otherwise the repair costs can be too high to bother). If you know what to look for then almost any year C4 could be a nice car. Plenty of 96s are junk -- and plenty of brand new cars are riddled with problems. Don't get too excited about the first Vette you find -- if you don't know what to look for you should do some research or bring someone that does know... You don't have to get the newest car you can afford, but don't at all be cheap or you will end up broke.
Old Jul 26, 2006 | 02:45 AM
kopbet89c4's Avatar
kopbet89c4
Since I like living simple, I'd say get an L98 car and put a MiniRam in it. JMO but I think this intake is the most problem free intake I've ever dealt with. You might lose a tiny bit of bottom end umph, but diagnosis should be relatively easy. I wouldn't have to worry about TPI runner gaskets. Also the access to the fuel rail and injectors would be so much easier. No Opti problems to deal with either. If I had to do it all over again, I'd pick a 91 over my 89.
Old Jul 26, 2006 | 02:59 AM
skeet's Avatar
skeet
Having owned both engines I would say go with the LT1. It is a more powerful engine and I did not like the way the L98 runs out of power so early on the rpm band. However, if I had to decide between a really nice looking, low mile, mint L98 over a high mile less cared for LT1 car I would consider the L98.
More important, to me, as to wether the car has the LT1 or L98 is getting a HD suspension car with the Z51 or Z07 option. Most Z51 or Z07 cars have other important equipment that you can only get with this option, like a very quick steering ratio which is absolutely great, freer flowing mufflers, HD cooling, PS cooler, performance axle, wider wheels, besides the real Corvette type of handling for which I bought a Corvette for in the first place.
You need to drive both.
Old Jul 26, 2006 | 06:39 AM
Joe C's Avatar
Joe C
i disagree - always go on well maintained and condition first, and newest second.
Old Jul 26, 2006 | 07:32 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
100%, but do your homework.
As mentioned a '96 could be total junk and an '85 model may be pristine, but your price will reflect the condition in most cases. Bring a vette expert with you when you shop around. You have to play it smart and check everything out. The condition of the interior(carpet and seats mainly), the paint, the tires, brakes etc.
These are all the big dollar items that people overlook. If you never owned a vette before and you buy one that needs new tires, prepare for a $1000-1200 bill for a decent set of tires, for seats and carpeting, about $700-1000 for seat covers(new) and around $500 for carpet.
Check the weatherstripping, genuine GM replacement will run close to $1000 for the entire set.
True you can buy cheaper inferior products, but why?
I'd rather buy a high quality well maintained 96 with 200,000 miles than a neglected earlier year that may only have 30,000 miles. And the price for either may not be that far apart.
Old Jul 26, 2006 | 08:00 AM
Paul Workman's Avatar
Paul Workman
I vote for the lowest mileage, newest, best cared for car you can afford first.
Second, the L98/LT1 is a matter of preference, with the edge to the LT1 in the quarter mile. The L98 is "old SBC" and is easier to modify and work on.
I like the LT1. The LT1 with it's flat torque profile, especially with the manual ZF6, is a joy to drive on a twisty road. The torque curve is so flat that that virtually anywhere in the rpm band you have the same torque. This makes for easily powering out of the curves as there is no sudden surge of torque just at the critical moments! From just off idle you have 90% of max torque, and it is ramps up smoothly to the rev limiter!
If you decide on the LT1 car, I recommend the '95 or 96 which has the positive ventilation in the Optispark which removes the buggaboo issues of the earlier Optis (but I still wouldn't hose it down at the car wash either!!).
You'll have to drive 'em both to see what you like.
P.
Old Jul 26, 2006 | 08:05 AM
redcorvettedave's Avatar
redcorvettedave
.........start with an LT4 and work your way back!
Old Jul 26, 2006 | 08:36 AM
mseven's Avatar
mseven
That sums it up with the 96 representing the most sopisticated of the c-4 gen. cars. From there it becomes all about your budget. MO
Old Jul 26, 2006 | 09:01 AM
kopbet89c4's Avatar
kopbet89c4
91 is the best L98 and the 95 is the best LT1. I wouldn't wanna deal with the OBD2 mess on the 96 cars.
I'm not really an LT1 guy, but definately know much is interchangeable between the 2 except for a few things like the heads. The block just circulates coolant in the opposite direction. I'm pretty damn sure that you can modify an LT1 to outperform an LT4.
Same goes with the L98. It could also be made to rev up high with a good cam, nice flowing heads, a MiniRam intake, and a nice flowing exhaust system.
Old Jul 26, 2006 | 09:11 AM
90steelblue's Avatar
90steelblue
body style comes into play here too..
The only year the L98 came with the new(er) bodystyle was in 91, with the rounded front bumpers and squared tails lights.
So if you like the l98 and the newer bodystyle, then you only have 1 year to pick from..
It may be a determining factor for you in your engine choice.
I would choose the car that was maintained the best though, you'll have more fun with the car, and more money to play with for mods.
Old Jul 26, 2006 | 09:30 AM
SJW's Avatar
SJW
P.
You've received a lot of good advice here, but I like Paul's best.
The L98 is a great engine. It's a workhorse, and it makes great torque below ~4500 RPM. Above that, it starts to run out of breath as a result of the long runners on the TPI setup.
The LT1 will pull hard all the way to redline.
You really can't go terribly wrong with either engine, so long as it is in good condition. I've driven both and either of them will put a grin on your face. Both are strong enough to deliver enthusiastic acceleration.
Be well,
SJW
Old Jul 26, 2006 | 09:50 AM
vader86's Avatar
vader86
Do you see me telling him to get a paint-chipped 96 with 257,000 miles?
Common sense comes into play dummies.
To Lt1 V.s. L98???? Help!!!!
Old Jul 26, 2006 | 11:00 AM
Demonic85's Avatar
Demonic85
Personally I like my L98 over the LT1 for several reasons. Like others have said the L98 has a lot of low end power, you'll beat most cars off the line in a drag race. They're easy to work on, no major electronics. The LT1 on the other hand is the other way around, they keep pulling at higher rpms. One of the major problems with these engines though is the Optispark distributor. Its sensitive to moisture and unfortunately sits right below the water pump
You should test drive corvettes with both engines and see which one you like best though. Good luck
Old Jul 26, 2006 | 11:02 AM
kguillen's Avatar
kguillen
Cruising
I didn't want to get in on this post because the previously stated reason "starting a feud." BUT, as the coment was made "I'm pretty damn sure that you can modify an LT1 to outperform an LT4.", I feel the NEED to chime in.
Taking it from a engineering view and a personal experience (I own a 96w/LT-4 and six speed) let me say that this comment is ludicrous, and I'll tell you why.
1) The LT-4 was designed with more precision parts, lighter parts and better machining in an effort to reduce weight and increase rev potential, thus increasing torque and horsepower, (ie; 330 hp/340lbft/ 10.8:1 compression for the LT-4 vice 300 hp/ 300 lbft/ 10.4:1 compression for the LT-1)
All that said, if identical methods and parts were used to increase HO/TQ/ compression in both the LT-4 and LT-1 engines, it is absolutely common sense that the LT-4 would fair better. After all, it is starting with more. It doesn't take a math professor to figure that out and it is not rocket surgery.
My personal experience is that I have smoked several slightly modified (better breathing) LT-1s with my stock LT-4.
Enough said, or rather written. Hope I didn't bark someones head off.
Old Jul 26, 2006 | 11:10 AM
drewk86's Avatar
drewk86
thanks for the info guys, i guess that i need to test drive both b4 i make a decision, not to mention getting my current ride sold so i can have the cash in had to buy one! HAHA
But i have one more question, I love a stick shift, is it that big of a deal if i find a good deal on a vette and its not??
Thanks, Drew
