4+3 help, HELP!!
Old Jul 26, 2006 | 08:16 PM
jordanpingrey's Avatar
jordanpingrey
Default 4+3 help, HELP!!
I have a beautiful 1988 black/ black w/ 4+3 Doug Nash Trans. with now 95k on the odometer, my problem; Car while in 4th O/D will slip into 4th gear regular while driving down the hiway at 60mph and then seconds later jump back to 4th O/D. More information; when in 4th O/D and I punch it "go faster," the car does what it is suppose to and down shifts into 4th gear but when I let up on the pedel the car will sometimes stay in 4th gear and not transfer back to 4th O/D. More information; when in 4th O/D, punch in, back off the gas the car will go back into O/D but then will slip back into 4th gear and then back into O/D basically going between O/D and regular output. Additional info; Car will sometimes perform this situation while in 3rd and 2nd O/D.
My question: What is going wrong?
How do I fix it?
Thanks in advance
Old Jul 26, 2006 | 08:47 PM
c4sforever's Avatar
c4sforever
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
check fluid level or change it all together. brb with a $$$ saving tip as well.
Old Jul 26, 2006 | 08:51 PM
c4sforever's Avatar
c4sforever
St. Jude Donor '06
when you change the tranny fluid ask the guy at the parts store for a filter for a 69 "ford" rachero with a 5.7 liter. Autozone has 'em for $7.00 as apposed to $19.99 + shipping from Mid America.
Old Jul 26, 2006 | 09:03 PM
scorp508's Avatar
scorp508
Post here: http://forums.corvetteforum.com/forumdisplay.php?f=48
Old Jul 26, 2006 | 10:01 PM
matrix040's Avatar
matrix040
also check your O.D. switch connection. my 85 did the same thing and the connection was bad. mine is in the console. fixed it and has worked great since.
To 4+3 help, HELP!!
