cracked floor pan
I was pretty scared when I first tackled it but I built a couple of composite airplanes back in the early eighties and the motor skills came right back. The stuff's VERY forgiving.
Mine turned out much better than the one they did recently in Vette or Corvette Fever. (Can't recall which.)
Go to www.aircraftspruce.com and order the "safe-t-poxy" and micro balloons, along with a small quantity of 3.7 oz cloth.
Using a die grinder, clean up the ragged edges of the hole. (If it's only cracked, you can use super glue (no s__t) and just slightly groove the crack on both interior and exterior. Flood the crack with super glue and you've got a sound, structural repair. (Ref "How to Repair Plastic Bodywork" by Kurt Lammon, page 36 under SMC repairs.)
If the floor is holed, make a single-ply layup for the exterior. That will create a basin into which you will fill, from inside the car, a slurry mixture of resin and balloons. (The balloons are hollow glass spheres and, when mixed with the epoxy resin, create a structural material. It's in the Structural Repair Manuals for each of our aircraft fleets.)
Once the slurry has cured, typically the same time as a fabric/resin layup, you can sand/sculpt it to shape.
Rotsa ruck, fryboy. Holler if you need more info.
What is cool of this glue is that it bonds even if the part is a little bit oily or fuel soaked. Not that you would like that to happen because a clean part will give more adhesion to the glue.
After you glue the "puzzle" back in the floor pan I suggest that you soak all the cracks with this product and put some bicarbonate on it, spread a liberal part on it , wait till it is wet and blow away excess bicarbonate.
This will seal the cracks, provide some adhesion and will allow you to lay the fiberglass and soak it with whatever choice of resin you use without having it leak.
By the way, poliester resin is a very cheap choice and gives a very instantaneus result because it hardens very fast , but epoxy resins are far better and give grater results. Problem is cost and time to harden which usually is about 24 hours compared to 30 minutes of poliester resin.
Epoxy resins will absorb more of the vibrations that the car produces and this is a great thing because the resonance generated can cause poliester resin to crack or loose the bond with the sustrate.
I like epoxy resins from Ciba Geigy, they produce great products that work well everytime. I have used cheap epoxy resins just to find out that they will not cure so I have to clean my mess and prepare everything again.
Good luck with this proyect!
