AC controls question
Old Jul 27, 2006 | 06:17 AM
honda hunter's Avatar
honda hunter
Default AC controls question
Why does my POS ac controls look like this:
And some people have the same year and theres looks nice like this:
Are they interchangeable?
Old Jul 27, 2006 | 06:45 AM
Jet-Jock's Avatar
Jet-Jock
One is the manual AC the other is the C68 option Electronic Air.
I don't know if that is the only component required.
TTT
Old Jul 27, 2006 | 06:56 AM
corvette-pilot's Avatar
corvette-pilot
Originally Posted by Jet-Jock
One is the manual AC the othe is the C68 option Electronic Air.
TTT
Old Aug 1, 2006 | 01:34 AM
Coconut's Avatar
Coconut
Default Intercgagable A/C control head
If anyone knows, I wish they'd post.
I hate my AUTO system. I prefer manual.
I'm guessing that they're not interchangable. If I remember correctly, the heater door operates manually on yours. The auto controller has a motor. I think that the auto uses the sun load sensor, while your's doesn't. I'm sure there are other differences, too, since there are AUTO buttons for both the temperature and fan controls on the auto unit. My auto unit constantly tries to reset to 75 degrees. It's annoying. I'd rather put the thing on 60 degrees & freeze. I don't need the computer trying to tell me that my car is too cold inside of it. It's not too cold for me in hot FL!!!
Old Aug 1, 2006 | 04:09 AM
honda hunter
Intresting. With that said I'll keep mine then
Old Aug 1, 2006 | 05:45 AM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
TTT
it is not the only part of that puzzle. Here is a link that shows the other half http://www.batee.com/corvette/acrepa...oard/c68.shtml and how to repair it. This unit is hidden under the dash, above the steering wheel and is not easy to get to.
Old Aug 1, 2006 | 07:13 AM
Jet-Jock's Avatar
Jet-Jock
For those with C68 AC, print that page to a PDF and save it. Good info.
Old Aug 1, 2006 | 10:02 AM
HG's Avatar
HG
Was that thingie out of a vette or the space shuttle.
Old Aug 1, 2006 | 12:16 PM
Jet-Jock's Avatar
Jet-Jock
Both dual use product LOL.
Old Aug 1, 2006 | 02:12 PM
Coconut's Avatar
Coconut
Default Too Familiar!!!
I'm way too familiar with that program module. The vacuum lines are too short, & the plug for both the vacuum lines & wires should be on the bottom of the unit where it mounts for easier access. I've had to replace mine. It's a total pain to get to. If I have to remove that thing again, Ilm going to put a custom mount under the dash for easier access!!! I may just mount it upside down, & make the vacuum hoses longer. That would work.
Also, I think the Space Shuttle program would condemn this thing, since it breaks down, & one can barely get to it to fix it. All of the crew would die.
Old Aug 1, 2006 | 02:51 PM
SunCr's Avatar
SunCr
Programmer usually only works right side up (or as mounted) - I wouldn't change it (permanently) without testing it out first.
Old Aug 1, 2006 | 03:14 PM
topgunvette's Avatar
topgunvette
i have a '86 with the auto one mine looks a bit diff but same thing, i too would prefer the manual over the automatic one...
To AC controls question
