sawblades
Old Jul 27, 2006 | 05:36 PM
guyjay777's Avatar
guyjay777
Default sawblades
92 auto..my blades need some help..a little dull...best products to use?...thanks in advance.
Old Jul 27, 2006 | 08:24 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Mothers has a newer product that is a big soft ball that attaches to your drill. Just coat it with their aluminum polish product and go to work on the wheels. If this doesn't help then you will need to strip the clear coat off first and then go to work with the Mothers.
I saw it advertised on Overhaulin. I might be confused though and the product might actually be made by Flitz instead of Mothers. Pep Boys carries it.
Old Jul 27, 2006 | 08:38 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Your sawblades are clearcoated (at least, they were from the factory), so a metal polish won't do you as much good as a good wax or paint polish.
I.e. they are painted, so treat them as you would any other paint.
Larry
code5coupe
Old Jul 28, 2006 | 10:15 AM
Casethecorvetteman's Avatar
Casethecorvetteman
Are they polished or standard finish? Are they clear coated? I wouldnt metal polish them in any circumstance, there is a couple pics of mine below, i used an Australian made product called Bowden's Own auto body cleanser, then i waxed them.
Old Jul 28, 2006 | 09:46 PM
rubyred93's Avatar
rubyred93
1992 sawblades were painted, 1993 - 1996 sawblades were cnc'd and then clear coated. 1992 blades are different in that respect.
If your rims are original, you'll want to treat them much as you would the painted panels of your car. A quality paint cleaner such as Klasse All In One is a good choice. If you don't want to go that route, you can also use a cleaner wax, such as Mother's.
Are you trying to remove brake dust? If so, be very careful in your choice of wheel cleaners as many are acidic and will quickly ruin the surface of your rim. You actually want a wheel cleaner that requires aggitation with a brush in order to be effective. You don't want a spray on/hose off wheel cleaner and the bottles of different products will state what they require to be effective.
An excellent/safe mail order wheel cleaner is Eimann Fabrik High Intensity, or you can use an over the counter product like Mother's Aluminum Wheel Cleaner. Never had a problem with either product.
Old Mar 28, 2014 | 11:01 AM
rsmith4604's Avatar
rsmith4604
McQuire's....I just bought it....not sure about the spelling. It's a cone.....better than the ball.
Old Mar 28, 2014 | 07:25 PM
skyhawk50's Avatar
skyhawk50
Maguire's. I use a lot of their products.
Old Mar 28, 2014 | 07:35 PM
1993C4LT1's Avatar
1993C4LT1
Old Mar 28, 2014 | 07:59 PM
Daytona69's Avatar
Daytona69
Considering this was originally posted in 2006 I'm guessing the guy figured out what product he wanted to use
Old Mar 28, 2014 | 09:09 PM
1993C4LT1's Avatar
1993C4LT1
Didn't even notice that.
Old Mar 29, 2014 | 12:51 AM
DucXL's Avatar
DucXL
so...my low mileage '89 "sawblades" have a nice machined finish/w painted inserts.The clearcoat is cracking and minor oxidation is starting to form.The question keeps coming up.
What method would one use to refinish as factory delivered ? ../w money no object...Chemical strip and powdercoat?
Old Mar 29, 2014 | 08:24 AM
rsmith4604's Avatar
rsmith4604
Me neither....where do you see when the thread was posted?
Old Mar 29, 2014 | 02:21 PM
Daytona69's Avatar
Daytona69
Right above the forum name...7/27/2006
Old Mar 29, 2014 | 04:30 PM
rsmith4604's Avatar
rsmith4604
Thanks Daytona....I see it now....Ya can't fix stupid....give me some slack....I'm old and getting dumber every day.
Old Mar 31, 2014 | 07:08 PM
rocco16's Avatar
rocco16
Right above the poster's name...7/27/2006
Fixed it for ya'.
Old Apr 1, 2014 | 01:21 AM
Vetteblack-96's Avatar
Vetteblack-96
Is there any hope for neglected sawblades with brake dust caked on them? Been on for a while, unfortunately.
Old Apr 2, 2014 | 02:33 PM
VeryUnoriginal's Avatar
VeryUnoriginal
For me, I've been using Simple Green and lots of elbow grease. I got the majority of it off..
To sawblades
Old Apr 2, 2014 | 07:33 PM
Vetteblack-96
VeryUnoriginal, thanks, I'll try that. I guess a stiff brush is better than abrasive for this kind of thing.
Old Apr 3, 2014 | 12:23 AM
VeryUnoriginal
It got a lot of it off, but there's still a lot on there for me. I've got 21 years and 82,000 miles of brake dust caked on.. I'm sure there will be someone more knowledgeable that will let us know someway to get all of it off.
Old Apr 3, 2014 | 12:43 AM
Vetteblack-96
I haven't tried the oven cleaner method yet. That might take off the clear coat also. It's not a real big deal as I want to upgrade the wheels when I get new tires. I was just hoping to have someting decent for whomever might want to buy them. I don't want to just throw them into a dumpster
