Spicer U-Joints - Whose Got Them?
Old Jul 28, 2006 | 02:23 PM
C4boy's Avatar
C4boy
Default Spicer U-Joints - Whose Got Them?
The general consensus on the forum seems to be in favor of using Spicer u-joints. So does anyone know of an online supplier with a good price? No one locally seems to have access to Spicer. Rock has everything but.
'86, AT, rear half shaft joints 3.07 rear
Old Jul 28, 2006 | 02:27 PM
bogus's Avatar
bogus
Tom's Differentials, and if I remember correctly, they are the boxed Delco parts, so a GM dealer.
Old Jul 28, 2006 | 02:59 PM
vader86's Avatar
vader86
Tom's
Old Jul 28, 2006 | 04:03 PM
C4boy's Avatar
C4boy
Bogus, are you saying AC Delco reboxes spicer as standard practice? Rock Auto is the only place I've seen that has a few different AC Delco joints available. Called Tom's, no one's home and none of the distributors in my area seem to have access to Spicer.
Old Jul 28, 2006 | 05:33 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I got mine through a local truck driveline specialist who's a Spicer dealer. Because the company I work for does business with them regularly, I got them at the jobber price. But even retail should be reasonable through them. The numbers you want are 5-800X for the halfshafts and 5-786X for the driveshaft. Check under truck parts in the yellow pages.
Old Jul 28, 2006 | 05:35 PM
bogus's Avatar
bogus
Spicer is part of Dana. Dana provided the rear end and the ujoints as OEM.
I installed Delco ujoints, and I am pretty sure they said 'Spicer' on them.
Old Jul 29, 2006 | 01:24 AM
85 Z-51's Avatar
85 Z-51
napa auto parts u-joints for vettes are spicers, about $18.00 a piece, if i remember right
Old Jul 29, 2006 | 09:06 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Got mine at NAPA for $120 for all six.
Old Jul 29, 2006 | 09:41 AM
Corvette Kid
My NAPA store informed me that NAPA no longer offers Spicer joints. Perhaps they're wrong but that's what they said.
Old Jul 29, 2006 | 11:50 AM
Fast Eddiz's Avatar
Fast Eddiz
summitracing.com
Old Jul 29, 2006 | 12:55 PM
Mr Mojo's Avatar
Mr Mojo
I'll have to find out, my buddy owns two Napa's
Old Jul 29, 2006 | 01:19 PM
Mr Mojo's Avatar
Mr Mojo
I just called my buddy, NAPA doesn't stock them, but they can special order them and they aren't too cheap anymore.
Old Jul 29, 2006 | 01:26 PM
Corvette Kid
Good to have a definitive answer. Your price was probably the garage price anyway, since he's a friend, wasn't it? $120 is right around what the last set I bought cost, just a few months ago at jobber price.
Old Jul 29, 2006 | 02:19 PM
C4boy's Avatar
C4boy
Thanks for all the info so far. I did call a local driveshaft specialist but he didn't have the Spicers in stock. He could order them @ $35 each (which is probably list) so I passed on him for now. I usually use a friend's garage name to get dealer price, but I just gave them the part#.
We have 3 or 4 local Jobbers/wholesale distributors that most of the parts stores buy from, but none of them carry Spicer either.
I think Bogus is right in that the AC Delco boxed joints ($20 ea.) are probably Spicers. I'll check into that. A lot of the chains box other manufacturers products in their own packaging, so I'll check a local NAPA and Autozone as well. Summit online was NG and I think Tom was out to lunch or fixin someone's rear end.
I did find a bunch of good info and resources while looking into all this and and I'll post it when I'm finished.
Old Jul 29, 2006 | 02:37 PM
Corvette Kid
$35 is probably about right retail for the halfshaft joints but the driveshaft joints should be considerably cheaper as they are a good deal smaller. I'm thinking I paid around $25 per for the HS joints and maybe $15 or less for the DS ones the last time I bought them. I would be surprised if that's dealer retail ($20), if the AC Delco joints are truly Spicers.
Old Jul 29, 2006 | 04:31 PM
C4boy's Avatar
C4boy
Came back from Napa, Advance and Autozone. The standard joints that all 3 had in stock were stamped "china", as in made in. They all had grease fittings and all looked like the same joint. Just sold in Napa or PDQ boxes. The high performance joint the 3 stores list is probably the version w/o a zerk fitting.
Corvette Kid, the price on the Delcos came from Rock. And they seem to sell around dealer wholesale.
Old Jul 29, 2006 | 04:44 PM
Corvette Kid
I guess the only way to know definitively would be to physically compare the two, in lieu of someone knowing that information with surety.
To Spicer U-Joints - Whose Got Them?
Old Jul 29, 2006 | 09:27 PM
bogus's Avatar
bogus
I have had brute force ujoints for the last 4+ years and no problems...
I know they have a bad rep, but for street use, they seem ok.
Old Aug 8, 2006 | 05:00 PM
Wildcat1's Avatar
Wildcat1
Just got back from the shop, my inner left side halfshaft u joint is bad, the freakin thing was only a few months old. It was a china made pos from napa, I took the first one they gave me back because of this. The second one they ordered was called heavy duty in their books, it was obviously far from it. Called Tom's Differentials and ordered one from him for $29.75, he gave me part # UJ-13. It should be a very nice piece looking at the notations on his site, plus, it's a Spicer. I also now learned exactly how to tell if the ujoint is bad so I won't have to go through the guess work anymore.
Old Aug 8, 2006 | 05:34 PM
C4boy's Avatar
C4boy
I'm not familiar with the UJ-13 part #, though I've seen it on Tom's site. I had a local driveshaft supplier order a pair of Spicer 5-447x joints for me and they came boxed as solid, not greasable joints. So I'm still waiting for mine. If you get solid joints from Tom and they are really Spicers, check on whether or not you need to grease the caps before installing. Some of the solid spicer joints use a synthetic grease which is all that's needed.
