Well I hope this does not sound dumb, but can anyone help
me with this? how do you take the sun visors off without
screwing them up? I bought new one's and I'm trying to
replace them.
You remove the targa, remove the screws in the plate above the visor, then comes the trick of getting a screwdriver in to pry up the little teeth on the thing holding it all in.
You'll probably break it or at least a few of the teeth. And once it comes loose, the pieces inside might fly in 3 or 4 directions so be watchful.
Take the top off and remove the covers and i could after the bolt is removed that holds the bolt thingy in place you can actually unthread that flat washer thing just watch out because it is spring loaded
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
