Windshield fogging up
Old Jul 29, 2006 | 08:05 PM
chkita69's Avatar
chkita69
Cruising
Default Windshield fogging up
Has anybody had a problem with their windshield fogging up oin their C4 on a hot/warm evening. It's not a heater core problem, and I realize that if the blend door is hanging up a bit it could cause this... Was just wondering if anybody else had had this specific problem on their ride...
Old Jul 29, 2006 | 08:13 PM
IRAraid's Avatar
IRAraid
Default Foggy windshield on warm evening
My '95 does this occasionally. It did it many times before my grandson happened to be with me and noted that the fog was on the outside. Running the wipers proved his eyesight. Try it.
Hope that's it.
Old Jul 29, 2006 | 10:09 PM
85vet's Avatar
85vet
Cruise-In V Veteran
Yes - at least for me it is pretty normal.
Old Jul 29, 2006 | 10:54 PM
rdcamero's Avatar
rdcamero
Happens to me also.I notice it more after I have had the ac on park the car awhile and then drive it right after that again with the windows down and the ac off.
Old Jul 29, 2006 | 10:55 PM
the teacher's Avatar
the teacher
My 95 does the same. Only lasts a couple seconds. Usually when the top is off.
Old Jul 30, 2006 | 01:43 AM
Maui's Avatar
Maui
St. Jude Donor '08
I've noticed when I fire up the car with the AC going that for the first few minutes it blow cold air out the defrost vents. After a few minutes it slowly switches to the dash vents. If conditions are just right it will fog up the lower center of the windshield.
Old Jul 30, 2006 | 02:10 AM
mcnulty95's Avatar
mcnulty95
Old Jul 30, 2006 | 04:27 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
They all do that !Unless you clean the window and put a good wax on it .I use Zimol wax on the inside of the glass ,gets rid of my fog
Old Jul 30, 2006 | 04:51 AM
CMYC4GO's Avatar
CMYC4GO
There's not a car made by ANY manufacturer that doesn't fog up under the right circumstances.
Old Jul 30, 2006 | 05:58 AM
toptechx6's Avatar
toptechx6
If it is fogging on the inside and you are sure the heater core is okay, check the recirc door. It should be in the outside air position to clear the windshield, if it is recirculating (inside air) you will not defog. The blend door controls heat but should not cause your problem.
Old Jul 30, 2006 | 10:58 AM
MrRenoman's Avatar
MrRenoman
Protectents used on the dash or seats or anywhere else may be causing the symtom. I don't use this stuff much but I had a first aid kit in one of my cubbys for the longest time. Seems that one of the contents leaked out so I tossed the whole first aid kit away. My frequent windshield fogging cleared up.
Art
Old Jul 30, 2006 | 12:29 PM
1994vette's Avatar
1994vette
:yesnod i can park mine and go inside and come out and refire it up and it fogs up the windshield.
Old Jul 30, 2006 | 02:03 PM
Demonic85's Avatar
Demonic85
Yes, happens on an occasion, but flip on the defrost and in about 10 seconds its all gone
Old Jul 30, 2006 | 03:06 PM
Aardwolf's Avatar
Aardwolf
Any leaks in the weatherstrip? Some moisture getting in could do that to.
Old Jul 30, 2006 | 06:40 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Did you see Naomie Harris in the shower scene from Miama Vice yet? THAT would fog up my windshield in a hurry!
Old Jul 30, 2006 | 07:36 PM
CJB's Avatar
CJB
Think..rackish angle of the windshield glass provides alot of area. Cold inside, hot outside....vice versa will give you condensation on the inside or outside. The deciding factor on location of condensation is which side has the warm air!
Old Jul 30, 2006 | 11:57 PM
ol school's Avatar
ol school
My 96 does the same,until a/c comes thru the vents...
Old Jul 31, 2006 | 06:28 AM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
I guess I have to go se Miami Vice now.
Old Jul 31, 2006 | 01:32 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VIII Veteran
Have you peeped Sallie Richardson-Whitfield on Eureka? That slim can fog a ****'s windscreen, too!
http://www.imdb.com/gallery/granitz/...rdson,%20Salli
To Windshield fogging up
