Adjustment after intake gaskets changed
1. Check the reisitance of the injectors. All 8 injectors should be very close to the same reading. These are Bosch style and are usually reliable.
2. Examine each vac line and make sure it is correctly routed to its proper position and tight on the fitting.
3. Make sure all bolts on the intake and other removed parts are tight as they should be.
4. Check the timing of the engine to make sure it is set properly.
5. Do a base idle check to assure the TPS is properly set.
Changing out the intake manifold gaskets requires many parts to be disconnected and reconnected. In addtion, there are areas that must be sealed properly for the car to run correctly. I would guess that something has not been reinstalled correctly ...... assuming you have good injectors.
Here is a contact for injector questions as I am not an expert on this: Rich Jensen at Cruzin Performance is very good and is a straight shooter. His email address is: rich@cruzinperformance.com
Good luck and let us know how this turns out!
I used this forum suggested technique with great success to find a vacuum leak I have in my intake system, and I think it is worth the time for you to check yours.
1)Find a person who smokes.
2)Remove the snorkle going to the throttle body
3)Insert a 3-4' piece of tubing into the throttle body and let the plates close on it (make sure it is stiff enough to not be crushed).
4) Seal up the entrance to the throttle body (a towel was suggested, but I found that pieces of wide masking tape worked much better).
5)Have the smoker exhale into the tube. It will take a while to fill up the entire TPI system, so expect this to take a few minutes.
6)Once the intake is full of smoke, every additional exhale will push smoke out of any vacuum leak.
HTH!
Unfortunatly the smoke test revealed only that the throttle body shaft has a slight leak and the top rubber seal on the passanger side valve cover has a slight leak. Both of these were already there. If I had a leak it should have shown itself due to the fact that I used a porta power air pump and rigged two plastic cups togeather and used 4 cigerettes to force the smoke, under presure, into the hole engine. So heres another question, if I have an internal intake gasket to head leak, how do you diagnose that?
Lee: Find someone with a scanner and see what is going on with your engine sensors. This will lead you to the problem. Otherwise, you will just be throwing $$$ and time into the car and you may not luck up and find the problem.
