ac compressor types?
Old Aug 6, 2006 | 11:21 AM
morgan_kane's Avatar
morgan_kane
Default ac compressor types?
Rockauto has two acdelco reman compressors - another has r4 marking - what does it mean?
Also there is one with long shaft and one with short shaft. What does this mean?
Old Aug 6, 2006 | 11:31 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
It has to do with which clutch you are using. You should always replace both the comp and the clutch at the same time, and believe it or not, it's usually cheaper. (At least it is at Auto Zone.)
Old Aug 6, 2006 | 01:03 PM
morgan_kane
Do you mean both markings has to do with clutch?
I think shaft lenght is associated with clutch type, but what a heck is r44 ??
Has it something to do with refrigerant?
Old Aug 6, 2006 | 01:50 PM
zr1fred's Avatar
zr1fred
I'm not sure, I have run into the situation where the compressors are filld with different oil for R-12 refrigerant or with oil for 134A. I'd go with the latter if that is the case. You should convert now at any rate. There are different shaft lengths on the R-4 compressors, and that has dealt me fits when changing clutchs.
Old Aug 6, 2006 | 02:17 PM
Daffy's Avatar
Daffy
Florida turtle advocate
St. Jude Donor '05-'06
The R4 is a radial compressor used from 84-87.....There are two different units used from 88-91.The R12 compressor will work with either R12 or R 134 but won't fit in place of the R 134 compressor which will fit from 88-96.SO that makes three that I know of.
Old Aug 6, 2006 | 02:32 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
This will probably confuse more than it clarifies.. but I bought the second one listed here:
http://forums.corvetteforum.com/show...ght=compressor
It's a new Delco unit. There are different p/ns for original compressor, replacement new compressor, reman compressor... and the p/ns have changed as well.
R4 is the type of compressor design use on a ton of cars. Yours is an R4 compressor, no matter which one you buy for your car.
morgan_kane
I have -87. So R4 is right choice?
Old Aug 6, 2006 | 02:56 PM
CentralCoaster
R4 isn't a choice. They are all R4. That second one down will work for you if you want a new one.
Reman is listed on there as well. I don't know what any of the non-delco ones fit, and I didn't want to waste my money on a chinese rebuild, so I didn't bother trying to figure out the long vs short, etc.
You can also get yours rebuilt at a local shop for less than all of the above, and support your local repairman.
Old Aug 6, 2006 | 03:01 PM
nutz4c4's Avatar
nutz4c4
Yes R4 compressor.I just replaced on my '86 with Delco #15-20227.This was a new compressor with clutch.Works perfectly.Don'tforget to replace the accumulator,orifice tube and the O rings.
Old Aug 6, 2006 | 03:12 PM
zr1fred's Avatar
zr1fred
Auto Zone is usually the cheapest if you go re-man, alot of people don't, but they do have the best warrantee, and they will sell you a New Unit too, usually cheaper too. I agree with CentralCoaster on the local rebuilder part!
Old Aug 6, 2006 | 04:10 PM
morgan_kane
Sorry, can't find second one as a new compressor. Can you please give me part number?
How can i identify right compressor? Rockauto lists all of them for -87.
Did you get new orings with compressor? Or did you order them separately? i have new accumulator already.
Old Aug 6, 2006 | 07:37 PM
CentralCoaster
That's the one I got from Superior Chevy. Haven't put it on yet.
"Assembled in the U.S. of U.S. and foreign components"
"AC-Delco Seal Washer Kit - Made in People's Republic of China"
To ac compressor types?
