Gas?
Old Aug 7, 2006 | 09:05 PM
photoguy's Avatar
photoguy
Default Gas?
My fuel tank says high octane recommended. How much o a difference is there between 89 and 93 octane? With the price of gas is it worth it???
Old Aug 7, 2006 | 09:14 PM
rws.1's Avatar
rws.1
does your car knock under full throttle and heavy load?
If not you don't need it. What octane does the manual recommend ?
Old Aug 7, 2006 | 09:18 PM
photoguy's Avatar
photoguy
Default gas
No, I have no problem with the 87 octane but I do put the 93 in about every other tank.
Old Aug 7, 2006 | 09:20 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
My 1989 says to use 91 but I can't find it around here so I mix 89 and 93 in equal parts. Kind of a PITA but the car likes it fine even in this heat. BTW fill out your profile and you will get more answers. Need to know what you have, be specific.
Old Aug 7, 2006 | 09:23 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
High octane = 91+ If your choices are between 89 and 93, you should go with the 93 on your car.
Old Aug 7, 2006 | 09:24 PM
photoguy's Avatar
photoguy
Default gas
I have a 91 lt98 6 speed. The manual recommends 91 or higher.
Old Aug 7, 2006 | 09:32 PM
RRT vette's Avatar
RRT vette
Around here we have 87, 89, and 92 octane. My 95 doesn't mine any of them but the 86 only gets the 89+ due to knock counts. Ocassionaly I will see 93 octane at the pump.
Old Aug 7, 2006 | 09:40 PM
BADDUCK's Avatar
BADDUCK
Use 91 or 92 if you can find it. Anything more than your engine requires is a waste.
Old Aug 8, 2006 | 12:47 AM
andon19's Avatar
andon19
St. Jude Donor '09
def. need 91 or above... anything else you will get knocking...
Old Aug 8, 2006 | 01:22 AM
Paul G's Avatar
Paul G
These cars have a knock sensor. If you run a lower octane than 91 you most likely will not hear anything. The sensor will pull out timing till the knock stops. Problem with that is you will loose power and efficiency. If you use premium fuel, 91 or 93 it should be okay.
Old Aug 8, 2006 | 01:41 AM
ol school's Avatar
ol school
I tried less octane gas it seemed to run okay,but I got better milage
out of the higher octane gas.. Its only a couple of dollars differance in pricing.Best to go Better.
Old Aug 8, 2006 | 07:44 AM
Aquaman92's Avatar
Aquaman92
I use 93 octane premium at the cheapest place I can buy it (usally Murphys Mart or Sams club)
Old Aug 8, 2006 | 09:17 AM
SJW's Avatar
SJW
Fill with 91 if you can find it. Use higher octane if 91 is unavailable, or as Badduck suggested, mix 89 and 93 in equal parts to get the 91 octane you need.
As Paul G said, the ECM will retard the timing to prevent detonation if the knock sensors detect any trace of knock. This will save your engine from detonation-related damage, but will have detrimental effects upon the performance. It's not worth it. Let the engine run with the spark advance curve it was designed to use -- this requires the recommended fuel. Your engine will be happy, and so will you.
Be well,
SJW
Old Aug 8, 2006 | 10:46 AM
redwing76's Avatar
redwing76
I have two cars that require premium, and I use 91 and 89 with no problems.
Premium here is $3.35 a gallon. I never use the lawn mower gas though.
Old Aug 8, 2006 | 11:10 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
I use 91 mid-grade or 93 premium in my LT1 and haven't had any problems.
To Gas?
