I tried posting in the audio section but no replys. i wanna take out the front bose speakers on the bottom door seals. how do i take the carpet off to get to it i found the two screw on the outside when u open the door any other help would be great thanks.
Taylor T
Whoa, Now you are in for some work. I did both of mine, had to rebuild the amps. You have to remove the whole door panel, starting at the door handle plastic. Unless you have an urgent need to get in there. I would think it over. The carpet is glued to the door panel.
remove the 4 screws on the outside of the sill. remove the plastic panel at the door jam (it's about 8" long, and ~1.5" wide, with a couple of screws holding it in place).
Lift the sill from the back, and the entire sill will then come off.
