Pulley on smog pump delete 91 l98
The bearing in the smog pump delete idler wheel is going bad (Breathless ). The bearing is molded into the wheel & can't be pressed out without tearing up the wheel .I've been looking In all the top name auto stores for the replacement wheel ,some are close but none have the grooves in the drive surface.
Anybody have any idea on where to get one ? The wheel is a DAYCO #00032 with a bearing# 6203 lh & has 5 grooves in the belt drive surface . The wheel is 4 3/4 " x 1 1/8 " .
The wheel I tried to use is proper size but it has a smooth surface where the belt rides & has thrown the belt off. Something that has never occurred before .
Location: Swanton VT 2000 Navy Blue Mettalic M6 / 1991 Auto - Steel Blue 68,500 R.I.P
I can remember sme won ordering a Chrome one from there local store . I can't remember what store it was or what member it was . I would try to do a search If U can't get one from nappa like Vinnie had mentioned .
PatsFan
PatsFan
