Spare Tire
Old Aug 13, 2006 | 04:02 PM
92Beast's Avatar
92Beast
Default Spare Tire
I recently bought a 92 coupe. There is no spare tire in it and I plan to use it primarily as a cruiser.
What was the stock spare in this model?
I am running 255-35-18 on the front and 295-35-18 on the rear.
Will the carrier space fit a full size stock wheel and tire
Old Aug 13, 2006 | 05:01 PM
STL94LT1's Avatar
STL94LT1
Stock spare is a donut.
Old Aug 13, 2006 | 05:08 PM
trulytex's Avatar
trulytex
I have a 1990 Vert and the spare tire is one of the little temporary tires. They say that to carry a full size spare, the spare tire carrier hangs down quite low. I would just carry the temp spare and a credit card. If you have a flat, just limp in on the do-nut and then fix or replace the flat one at the nearest shop.
Old Aug 13, 2006 | 05:09 PM
Jeff Jewell's Avatar
Jeff Jewell
From: all the lakes and sprint car tracks in Northern California
I was faced with the same deal. I just got a 85 and it didin't come with a spare or jack. I checked around and found you need to get one that matches your year vette. mine was any 84 to 87. It has to do with the wheel offset. Dealer suggested trying junkyards ( Auto parts dismantlers ) I found one that specializes in GM and they had both the spare and the jack. took it right out of another 85 for me. $100.00
Good Luck, I'm sure the guys here can tell you the years that match up......
Old Aug 13, 2006 | 09:29 PM
drock92's Avatar
drock92
One thing bad is he says he's running 18's and '92's had 17's so he'll probably have to put a fullsize under there (which most likely won't fit) or will probably have to get run flats.
Old Aug 13, 2006 | 09:32 PM
DG'sVette's Avatar
DG'sVette
I'd say go with the cell phone / credit card spare.
Hopefully you won't need to use either.!
Old Aug 14, 2006 | 12:11 PM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
I have also read that the temporary spare tire (donut) is an integral part of your rear-end collision protection. If you look at where the temp spare goes, the front of the tire is right up against a frame crossmember with the fuel tank above it. Having seen that, I would be very hesitant to go without. Others will disagree I'm sure.
Old Aug 14, 2006 | 12:46 PM
AILERON's Avatar
AILERON
"I have also read that the temporary spare tire (donut) is an integral part of your rear-end collision protection. If you look at where the temp spare goes, the front of the tire is right up against a frame crossmember with the fuel tank above it. Having seen that, I would be very hesitant to go without. Others will disagree I'm sure."
I've seen something here on the Forum that installs a "hard bar" to replace a spare tire delete, probably for the same reason.
I don't think any weight savings is worth the loss of structural integrity.
(.02C)
Old Aug 14, 2006 | 01:21 PM
DG'sVette's Avatar
DG'sVette
Did not know that!
Old Aug 14, 2006 | 08:24 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
A A A
Old Aug 15, 2006 | 02:53 AM
xCCTer's Avatar
xCCTer
CF JASOC Member
Sorry, I never did answer your question about what should be in your spare tire carrier.
The tire should be a Goodyear Convenience Spare T155/70D17.
To Spare Tire
