Help Installing c-beam
Old Aug 14, 2006 | 10:02 AM
js292's Avatar
js292
Default Help Installing c-beam
Can anyone give me some help as to the easiest way to get the c-beam back in a 85 4+3. I guess I'm better at taking things apart than putting them back together.
Old Aug 14, 2006 | 12:25 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Stick driveshaft in, let ebrake cable hold end up. Slip cbeam onto rear diff first... keeping cbeam against tunnel side. Push back as far as possible with trans jacked up.
Pry trans over to driversside and get Lou Ferrigno to push C-beam up into place.
It gets worse on the ZF6. I ground off part of my Cbeam to make it reasonable.
Old Aug 14, 2006 | 12:33 PM
Dave89CC2's Avatar
Dave89CC2
Cruise-In VII Veteran
Get a BIG phillips head screwdriver. Put it in the bolt holes and use it to leverage the C-beam into position. That's the only way I was able to have the holes in the beam to line up with the holes in the transmission and rear end.
Old Aug 14, 2006 | 12:37 PM
js292's Avatar
js292
thanks guys, I'll give it another try this evening.
To Help Installing c-beam
