Temp gauge not working
Old Aug 14, 2006 | 12:51 PM
photoguy's Avatar
photoguy
Default Temp gauge not working
Just noticed my temperature gauge is not working. Could this just be a fuse??
Old Aug 15, 2006 | 12:59 PM
ThomasRetUSN's Avatar
ThomasRetUSN
It could be a fuse or it could be the temp sending unit or check the wire for the sunding unit. It may have came off. I had the same problem and it was just the connection off.
Old Aug 15, 2006 | 01:00 PM
ThomasRetUSN
It could be a fuse or it could be the temp sending unit or check the wire for the sending unit. It may have came off. I had the same problem and it was just the connection off.
Old Aug 15, 2006 | 02:41 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
if you have a 84-85, the sender is in the head between #1 and #3 cylinder.
If you have a 86-89, the sender is in the head between #6 and #8.
later ones I'm not sure. It's a single spade connector.
Old Aug 15, 2006 | 04:14 PM
TA's Avatar
TA
Your temp sender is in the passenger side head between 6 and 8. Make sure the wire is connected. I've knocked mine off a few times while changing spark plugs, etc.
Old Aug 15, 2006 | 06:22 PM
photoguy's Avatar
photoguy
I have a 91. Do you know where it tis??
Old Aug 15, 2006 | 09:02 PM
TA's Avatar
TA
I certainly do as I have a 91 also. Its on the passenger side, on the head, in between the rear most spark plugs. Hope this helps.
Old Aug 15, 2006 | 09:11 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I put a new connector on mine while the engine was out and damned if I didn't have to fix it again over the weekend as the wire had been pulled out. They're very vunerable where they are.
To Temp gauge not working
