Is this normal??
Old Aug 15, 2006 | 06:24 PM
photoguy's Avatar
photoguy
Default Is this normal??
I have a 91 with no mods. When I first start up it runs a little rough for a few minutes and then runs great.
I just changed the plugs and air filter and same thing.
Is this normal??
Thanks all!
Old Aug 15, 2006 | 06:31 PM
Jet-Jock's Avatar
Jet-Jock
Does it only occur from a cold engine and does it also happen if it was up to temp, then parked - hour or so later started up again?
Old Aug 15, 2006 | 06:33 PM
photoguy's Avatar
photoguy
It seems to run OK after warm up. Today it was 82 outside and it sat for about an hour and ran fine. It is just first thing in the morning.
Thanks for any suggestions.
Old Aug 15, 2006 | 06:35 PM
photoguy's Avatar
photoguy
Hey Jet Jock.
I see you are a pilot. What do you fly? I fly the Cessna 172.
Jet-Jock's Avatar
Jet-Jock
Ok do you monitor what coolant temp the engine is at before starting off from a cold engine? If so what is it?
Is it idling ok but just rough under a slight load when starting out?
Old Aug 15, 2006 | 06:37 PM
Jet-Jock's Avatar
Jet-Jock
At the moment nothing, although I'm in discussions with a company for a new flt ops position.
727, DC9, most of the major twins turbine and recip, in the early days all varieties of singles.
Old Aug 15, 2006 | 06:42 PM
photoguy's Avatar
photoguy
It idles fine. Just rough with a load.
I flew the 727 sim at Pittsburgh Airport. What a thrill!!!
Old Aug 15, 2006 | 07:02 PM
aminnich's Avatar
aminnich
Getting light smoke at start up? That might be a leaking injector. Easy to check.
I have about 15 minutes seat time in an F4C (vietnam era). Does that count? Otherwise about the same seat time in the C-130 (I was flight crew, but not pilot).
Old Aug 15, 2006 | 07:19 PM
Jet-Jock's Avatar
Jet-Jock
It all counts!
Now a days the sims are so realistic not only is training done in them but check rides too. For example in the triple 7 (B-777) the first time the crew see's the bird is when they are on the line. Everything is done in the sim.
Could just be just a cranky ole engine. Mine does that a little bit if I push it to go before it's warmed up. I usually just let it idle until temps are at 105°F then move out. Primarily I choose that temp as the O2 sensors should just be at operating temperature and the system is changing modes (open to closed).
Could be a dirty throttle body and/or IAC valve (not so much the IAC as that would show up after its up to temp) but since when one gets dirty the other usually is too. Check the backs of the throttle plates, remove air duct, open the throttle up and look at the plates and around the edges of the plates. Any carbon build up will prevent the plates from closing properly causing excess air entering the system.
Old Aug 15, 2006 | 10:26 PM
photoguy's Avatar
photoguy
OK. Thanks everybody for the help!!
To Is this normal??
