SYS and Security light
yes, that agrees with what i've been reading in the FSM.Btw, HG, here's a Quote from the FSM regarding DTC 41:
"A serial data malfunction may also cause an inoperative trip computer, loss of english/metric temperature display control on the C68 electronic HVAC control head, and loss of the 'Check Gauges' function.
If this fault is present, a C68 electronic HVAC control head LED will flash. Check for an ECM DTC 51, which will cause this DTC to set. The ECM DTC 51 problem will also be evidenced by the inability to flash ECM DTCs or to read ECM DTCs through the CCM."
The label on the C4 door says "Corvette Proud" the C5 door label says "The Legend Lives". It's true!
Well I hope you get the problem solved. It may not be anything more that a couple data faults on the SIO lines and clearing the DTCs you may be fine.
When I get home i will update on the exact trouble code. I also recently encountered #64 and #72 ASR/ABS DTC's. And of course, inevitably, I am still having the intermittent no-start situation because of all of this.
