R134a
Old Aug 17, 2006 | 11:56 AM
Skrud13's Avatar
Skrud13
Default R134a
How do I know if my AC has been converted to R134? Is there some physical sign that I can look for?
Old Aug 17, 2006 | 11:57 AM
scorp508's Avatar
scorp508
A conversion fitting on the Accumulator is a good sign. Or a sticker saying it has been converted.
Old Aug 17, 2006 | 12:21 PM
mikey whipreck's Avatar
mikey whipreck
The high and low side ports would have different fittings on them. Most likey if they are blue and red, it was- if they have black caps, its probably still R12...
Old Aug 17, 2006 | 01:08 PM
EvanD's Avatar
EvanD
CF Community Team
The modification to the fittings is making then asnap on connection instead of screw on.
Old Aug 17, 2006 | 01:34 PM
Goldcylon's Avatar
Goldcylon
Default re:when did 134 become standard
What model year did 134A replace R12 as a standard? I know somebody out there probably knows.
Old Aug 17, 2006 | 01:52 PM
SunCr's Avatar
SunCr
1994 and up are R134.
Frankly if you're not the original owner, I'd take it to a shop and have them tell you what's in it. A lot convert and don't note it or change the fittings. R12 is a threaded fitting and a conversion should be using Quick Connects threaded onto those old fittings; but what should be and what is aren't always the same.
Old Aug 17, 2006 | 03:15 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
on my '84 there is a sticker on the piece right behind my front right tire, it has been converted and the sticker says when, who, where...
To R134a
