shortened auto shifter
I think it could be done but the shaft will require some internal machining. I haven't really looked at it but it is a nuisence. Some day I will do something about it.
can you elaborate why one would need a short A4 shifter?
This was posted in the C4 Cockpit Pics thread...
This is my car...
It wasn't that hard to shorten. I actually did it while it was in the car.
You need to remove the trim around the shifter.
1) Get an old sheet or something similar and cut a hole in it to fit around the shifter.
2) Remove the center button by gently prying it up with a small flathead screwdriver.
3) The **** is held on with a snapring that you must get off using whatever method you can. I used snapring pliers and a flathead screwdriver. You probably won't be using it again so if it gets bent don't worry.
4) Once you pull the snapring off, then the **** should pull off. (I had to work with it to pull it up.)
5) After the **** is off you will see what the outer and inner shafts look like. You must cut both of them and then make a notch so it looks like it does now.
6) Measure the difference between the inner shaft and outer shaft. Then decide how low you want the shift **** to be. At this point it is personal preference AND you must "eyeball" the measurement since there is no real way to measure it acurately.
7) Once you decide how low you want it, then take some sort of cutting tool (dremel, air cutting tool, etc.) and cut the outer shaft to the proper length. This is where the sheet comes it to protect your interior from sparks and metal.
8) After you cut the outer shaft, then cut the inner shaft so that it sticks up a little higher (per your measurements earlier).
9) Then you have to cut a notch in the outer shaft so the **** will fit back on. I cut mine a little smaller so the **** was hard to push on and therefore will stay on without the snapring.
10) Push the center button back in.
Reinstall trim around shifter. To get the shift boot to clear the new shortened shifter, push it through the the trimwork (turning it inside out) then push it back through with the top part still pushed in on itself. This may not sound clear, but it will be when you are doing it.
That's it. Any questions, send me a PM or email.
I did used a pipe cutter which sliced through the shaft in a few minutes, then I groved a ring at the end for the snap ring. Filed the inside of the **** round. Cut the inner shaft so that it sticks up a little higher than the measurments that I made earlier. My measure 7/8 I added a 1/4 to it now my button sets up a little higher than before and easier to push.
works better shortened!!
