How do you change the lights in the dash?, obviously I'm looking for the easiest route. I want to change my dash to red light to turn my cockpit into a real cockpit. Please include bulb size and location of the bulbs needed to be changed. Gracias in advance!!
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
It's not the bulbs. You need to dissect the cluster assembly, and remove the circuit boards to get to the stock color gel, which is green, yellow and red. Then make your own color gel out. I cut out poster board and glued in carefully cut gels to match the LCD layout. I bought the color gels from gamcolor.com
