waterpump!
Old Aug 24, 2006 | 11:10 PM
batmanreno24's Avatar
batmanreno24
Default waterpump!
how can i tel if the water pump is doin its job or workin properly
Old Aug 24, 2006 | 11:18 PM
Yellow95's Avatar
Yellow95
Try this, turn on the heat and see if it gets hot. If it gets hot, its pumping water.
The only pump problems I know of is that they leak.
Very rare that they actually break.
Old Aug 24, 2006 | 11:29 PM
RonVette2's Avatar
RonVette2
If you see water leaking from the front area of your engine (waterpump area) your waterpump then is failing and will need replacing.
Old Aug 25, 2006 | 08:15 AM
jimmers's Avatar
jimmers
If the water pump is failing water will drip from the weep hole at the bottom of the pump.
Old Aug 25, 2006 | 08:55 AM
mikey whipreck's Avatar
mikey whipreck
mine cracked
To waterpump!
