LT4 questions
Old Aug 25, 2006 | 05:13 PM
Huntervangolf's Avatar
Huntervangolf
Default LT4 questions
I'm about to buy a lt4 coupe 96 with 87000 miles on it. It is pretty clean and seems to be taken care of. My questions is there any common problems with this setup with that many miles or is there any to come. Is the longevity of this etup reliable. Anything in particular I should look for before I buy it. I am a car enthusiast and own other cars and am mechnically enclined but looking for some heads up from you guy that know best. Oh, are part availability a problem for the LT4 since it was a one year production?
Old Aug 25, 2006 | 05:18 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
The LT4 is a stout and reliable motor... however the water pump and the opti are crap in damn near all LTx motors. Make certain those are okay before buying.
Old Aug 25, 2006 | 05:44 PM
rcolling's Avatar
rcolling
Check and see if they have been replaced yet.
If not you will need to replace it soon.
You just have to decide if its worth it to have an LT4...
Mine's got 106,000 on it and besides clutches from racing the only problem has been the Opti went. I made sure I had the waterpump changed at the same time.
Old Aug 25, 2006 | 05:58 PM
Huntervangolf
Okay like I said I work on my own cars and don't want to sound stupid but what is a opti?
Old Aug 25, 2006 | 06:12 PM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
LTx version of a distributor. It's mounted under the water pump so when that goes, the Opti gets drenched and generally needs to be replaced. Needless to say, when cleaning the engine area, keep water away from the optispark...
Old Aug 25, 2006 | 08:21 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Mounted on the FRONT of the engine, I might add. It is a bit of a bear to get to (I'm told, and SJW has a detailed post on how to replace it and do the wires/plugs at the same time). And while you're at it, mostly, DON'T USE water at all on the engine. Think of other "creative" ways to clean your various engine parts.
As to other things going wrong or to look out for, just a few little switches and glitches that'll crop up, nothing major. You may eventually need a clutch (dual mass flywheel is expensive but worth it to me, and to some others who've "experimented" with single mass flywheels). Brakes are supposedly easy, shocks, too.
All weather stripping tends to pull apart, it is expensive and not that easy to replace. Ck it out on the car. That's about it, but others will chime in...
Old Aug 25, 2006 | 08:28 PM
tobijohn's Avatar
tobijohn
Bench Racer
Originally Posted by LT4CompYell
Mounted on the FRONT of the engine, I might add...
:o Whoops, I forgot to mention that little fact. Oh, and about availability of LT4 parts - unlike the LT5, I can't recall anyone grousing about not being able to find them. Have you, Bill?
Old Aug 25, 2006 | 08:33 PM
Huntervangolf
Keep info coming! want to learn! Especially because the car has a few more miles than I told myself I was going to look for but car is close and my favorite color black.
Old Aug 25, 2006 | 08:48 PM
Achilleus07's Avatar
Achilleus07
Even though I just lost my LT4 you can see my thread at the top of general....I changed cams, headers and all of that myself in the car including sensors, water pump, optispark....none of the parts were hard at all to find. Summit has everything you will ever need and basic components (thermostat, sensors, etc etc) can easily be found at a Autozone, Napa, or Advanced. So no problem at all.
Just dont hit any concrete walls like me...its not pretty.
Old Aug 25, 2006 | 09:01 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
No, not really hard to find. It might get that way in another ten years or so. There are parts, however, that aren't being made any more but the availability of them and other, replacement parts still seems to be there.
Old Aug 25, 2006 | 09:24 PM
kwik_ta's Avatar
kwik_ta
Just like everyone said previously... I'll add that the opti generally takes a dump because of moisture. And ironically the opti is mounted behind the water pump which has a stupid history of puking all over the opti. See the chain reaction here? Your best bet is to buy the car and immediately order a Mezierre electric pump and MSD opti from Jegs and you should be golden!!! Ask me how I know
jonecap's Avatar
jonecap
It could possibly need intake gaskets replaced if they have not been already. Other than that...great motor. I love mine.
Old Aug 25, 2006 | 09:46 PM
Achilleus07
Depends what kind of car this is going to be. If this is his daily driver I wouldnt touch the Meziere Pump...plus you are going to get into the timing chain which is a pain in the butt because the cloyes doubler roller that works on the LT1 will not work on the LT4....trust me when I took my car apart I found out....he could use the heavy duty chain which is what I did...very nice. The generic water pump is just fine. The second edition Optispark that came with the LT4 also has very few problems compared to the earlier model. I had coolant and water...I would say almost a gallon....poor directly on my opti...wiped it off cranked up the car and never a single problem. I havent heard too many complaints from LT4 owners and their opti. Just my opinion.
Old Aug 25, 2006 | 09:58 PM
ALLT4's Avatar
ALLT4
Don't worry about the opti in a 96, it's an updated version that's a little more water friendly. I've pressure washed my motor a couple of times and it's still OK at 90,000 miles. Same for the WP.
On the other hand I'm probably on borrowed time, it's time to replace it just because we saw some strange peaks on the dyno the other day. This is really nit picking though, I don't feel it, the car runs great. The only thing/person that knows it's old is the dyno.
Except for the heads, cam, crank position sensor, and intake it's basically an LT1.
I did some things to my LT4 but I could have done nothing and I'm sure I'd still be driving it with no trouble. The things I did were things I wanted to do for more performance, not because I HAD to.
Get it, drive it, and don't worry about it until something goes wrong, although I couldn't hurt mine even with high mileage so you should be fine.
Old Aug 25, 2006 | 09:59 PM
redvette6spd's Avatar
redvette6spd
If this car has been maintained properly and cared for the miles it has on it ain't nothing. If it hasn't been abused or **** pounded it will easily make 200K. What is the sellers asking price?
Old Aug 25, 2006 | 10:22 PM
kwik_ta's Avatar
kwik_ta
Actually I got the Meziere on my somewhat daily driver and I wouldn't go back to stock for anything. The Meziere is a very reliable item and several other members stand behind it. My stock pump took a dump with only 28k on the heartbeat. If ya gonna replace the water pump ya might as well address the opti while you were there. On the timing chain note... a double roller can be used, but the crank position sensor has to be removed and programmed out of the system. I didn't see it as worht the trouble so I just used the HD chain.
Old Aug 26, 2006 | 06:42 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
With that mileage, if the Optispark was going to go bad, it would have already (and been replaced).
Actually, there is a whole laundry list of changes for the LT4, including rockers, rods, crank, pistons, ECU. It's a thoroughly hot-rodded LT1.
In fact, about the only common parts are the block and oil pump....and maybe the valve covers.
Larry
code5coupe
To LT4 questions
Old Aug 26, 2006 | 07:15 AM
ALLT4's Avatar
ALLT4
But as far as buying bolt ons, mostly LT1 stuff is the same. Unless you're in the habit of replacing rods, piston rings, and cranks.
If you buy headers, there's no LT4 specific, buy a TB, no LT4 specific, most everything that bolts on to the motor is the same as the LT1.
If you want to dig into the specifics this is a good web page...
http://www.grandsportregistry.com/lt1vslt4.htm
Old Aug 27, 2006 | 12:03 PM
Huntervangolf
The car seems to be taken care of and not much appearance of a hard life. My biggest concern is if something does go like a cracked head or manifodl or cam that the part is readily available, I mean without having to search bone yards or something. He is asking $16500.00. I can find standard coupes cheaper but like the fact it is a lt4 and should help with future resale. It has the chrome rims on it also. Another question for you guys is what about finding the removeable top? It has the tinted top, can you still buy that new, oem, aftermarket or do you have to look for used ones? Its not bad but has some scuffs and scratches common but would probably replace.
Old Aug 27, 2006 | 01:04 PM
Jet-Jock's Avatar
Jet-Jock
I think your worrying for nothing. If it is well maintain and you give it a good check out you'll probably be just fine. Most parts are still available from GM. Transparent roof yes through Melrose T-Tops, they are the authorized GM manufacturer and you can get a lower cost no hardcoat lens or the OEM hardcoated lens.
What the rest of the guy's have said. If you purchase and decide to swap out the opti and water pump remember to replace the bushing (seal) for the water pump drive shaft. That can cause a nasty oil leak with its' tight tolerances.
LTx engines have a tendency to develop an oil leak either at the forward or aft edges of the intake manifold. That is because it is a metal to metal seal and the RTV used tends to break down over time. Also can cause a nasty oil leak. Not a difficult repair take a few hours time.
Between the major Corvette vendors and GM you'll have plenty of parts available. One thing you'll learn as a Vette owner and that is the art of finding parts for the best price. Lot's of good people here to help should you need it.
First item you should buy is the Helm Factory Service Manual. Worth its' weight in gold.
