pls help
Old Aug 25, 2006 | 09:09 PM
batmanreno24's Avatar
batmanreno24
Default pls help
can i get step by step on proper ignition timing, how to set because ive done everything the book tel me am i doin somethn wrong ? im knew at all of this pls help...im stil backfiring ,overheating mannnn..
Old Aug 25, 2006 | 09:40 PM
bogus's Avatar
bogus
Be sure the wires are correctly installed.
Did you remove the distributor? If so, are you sure the engine and dist are lined up properly (#1 TDC).
A timing error won't cause backfiring... unless there are other problems...
Did you disconnect the EST wire?
What year?
Old Aug 25, 2006 | 10:34 PM
batmanreno24
What year?
84 i think i did disconnect, and i hav the distrib, lined up ,did the compression test(finger),im thinkin its aligned between 1 and 8 ,but if i cud get step by step starting from droppin distr,..
Old Aug 25, 2006 | 10:36 PM
batmanreno24
and the backfire accures in the intake
To pls help
