Coolant Bubble
Old Aug 29, 2006 | 03:15 PM
Skrud13's Avatar
Skrud13
Default Coolant Bubble
I replaced my coolant the other day and now I have an intermittent "Low Coolant" light. I assume that I have a bubble in there somewhere.......my question is, how do I get it out?
Old Aug 29, 2006 | 04:15 PM
HG's Avatar
HG
Look through the tips, you'll find one on how to purge air. What year do you have. One old trick that works is take the radiator cap off and let the engine run untill it reaches temp. If the air bubble reaches the top, it just vents out. keep an eye on the level when it gets hot, it will drop when the air is released.
Old Aug 29, 2006 | 04:41 PM
RRT vette's Avatar
RRT vette
This what you need to do on yours, Skrud13. Watch the temp and let it get hot enough for the thermostat to open.
Old Aug 29, 2006 | 04:51 PM
jimmers's Avatar
jimmers
Don't forget to hold the throttle at 2000rpms.
Old Sep 12, 2006 | 01:21 AM
Skrud13's Avatar
Skrud13
What is the point of holding the RPM at 2000?
Old Sep 12, 2006 | 01:25 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
The engine flow will be high and force out air from the block, thereby causing the seal. You add distilled water as it lowers, be sure to keep it at the 2k rev during the burping process, and keep at 2k while you install the rad cap, after cap installed then you can let the rev back to normal, also, an additional trick is to jack the front end up so that its higher than the back and do the burping process.
Old Sep 12, 2006 | 03:49 PM
HG's Avatar
HG
I just put a penney on the throttle stop and that kept the RPM's around 2K. Maybe it was a nickel. It does force the air out and heats up the engine so the thermostat will open. You must wait wntil the thermostat opens to get the air out. You'll see the water in the radiator tank begin to flow when it opens.
To Coolant Bubble
