Fire Extinguisher Mount...
Old Aug 30, 2006 | 03:16 PM
Brett Richmond's Avatar
Brett Richmond
Default Fire Extinguisher Mount...
Walmart is good for something, I was there this past weekend and bought a extinguisher for the car since you never know when you might need one. Well after looking at some of the kits that are for sale, I just drilled into the front of the plastic shell to mount the holder for this one.
Finished Product
Final cost was $11.00
Old Aug 31, 2006 | 06:10 PM
Kinkajou's Avatar
Kinkajou
Sounds like a good idea, and it should hold the extinguisher safely.
Old Aug 31, 2006 | 06:18 PM
zo1boy's Avatar
zo1boy
Glad to see safety is an issue for you, does it interfere with the person sitting in the seat at all?
Old Aug 31, 2006 | 07:06 PM
Brett Richmond
No interference at all, I went the cheap route like I normally do, there are kits out there that mount to the same place. I just installed a roll bar in my car but I wanted the extinguisher where I could get at it fast and easy. It will work for me if I ever need it which I hope I never do, I would rather use it for someone else than myself..
Old Aug 31, 2006 | 07:15 PM
champs65's Avatar
champs65
I did the same thing with the Walmart fire extinguisher. The best part is that its hardly visible as well.
Old Aug 31, 2006 | 07:38 PM
Brett Richmond
That is the best part because it doesn't make the car look rice at all even if it there for safety reasons.
Old Sep 1, 2006 | 08:20 AM
Vetracr's Avatar
Vetracr
WRONG PLACE TO MOUNT!!!! DID YOU EVER THINK WHAT WOULD HAPPEN TO THE EXTINGUISHER IF YOU GOT INTO AN ACCIDENT. PLASTIC ISN"T GOING TO STOP A STEEL EXTINGUISHER FROM REARRANGING YOUR LEGS. SCCA / NASA SAFETY STEWARDS WOULD HAVE APOPLEXY IF YOU SHOWED UP WITH THAT INSTALLATION. THE SAFE AND CORRECT WAY TO MOUNT THE EXTINGUISHER IS RUN A PIECE OF FLAT STEEL BETWEEN THE TWO FRONT SEAT MOUNTING BOLTS AND USE A STEEL QUICK RELEASE STRAP TO TIE DOWN EXTINGUISHER.
Larry
Old Sep 1, 2006 | 08:40 AM
runner140*'s Avatar
runner140*
Got a chrome extinguisher, metal mount and bolted to the harness bar.
Old Sep 1, 2006 | 11:15 AM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
Awesome mod.. thats on the passenger side right?
I REALLY need to get myself one. I had one just sitting in the back next to the nitrous bottle and cans of oil and coolant once.. but it was just sitting loose.
I RELALY like the looks of what you did with that!
I actually had an oil fire on my exhaust manifold once, luckily I was able to blow it out with a few quick short strong bursts of air (yeah, i blew on it). it put it out after a couple tries. After that, ive always been nervous from not having an extinguisher in the car.
Old Sep 1, 2006 | 11:57 AM
Brett Richmond
Actually it is the drivers seat, wanted to be able to get to it quick.
Old Sep 1, 2006 | 01:27 PM
Carl Johansson's Avatar
Carl Johansson
even better - the impact breaks it loose and it flies forward into you legs as well as the gas petal etc.
Man - I am really concerned about your safety attempts - roll bar is uncertifiable - fire extinguisher mount is not to any code - are you doing anything by the book - or are you just making it up as you go along?
Carl Johansson
Old Sep 11, 2006 | 12:52 PM
steve haverl's Avatar
steve haverl
Larry
want to do mine right - where do you get a 'steel release strap ' ?
Old Sep 11, 2006 | 04:54 PM
MYCoupe's Avatar
MYCoupe
They are normally included in a quality metal extinguisher mount. It's the part on the left in the picture below:
Old Sep 12, 2006 | 12:51 AM
FF1wms's Avatar
FF1wms
St. Jude Donor '11-'12-'13
Larry
very good info
Old Sep 12, 2006 | 01:15 AM
FF1wms's Avatar
FF1wms
Also make sure you mount it so you dont keep knocking the quick release open. While the rest of your car is being schreaded from the impact, there is a slight chance,that extinguisher might not stay put.
Old Sep 12, 2006 | 01:00 PM
hardlight's Avatar
hardlight
R-DRacing has a nice frame that attaches to the seat frame (easy to install), and is a crash worthy attachment for the fire extinguisher as well as the crotch strap for a 5 pt harness. BTW I am a big beleiver in Halon extinguishers, no experience with the new Haltron. Halon puts the fire out right now, the powder jobs have to be on whats burning and then the residue can do more damage than the fire. Halon gas migrates to where the fire is, my experience is with aircraft fires.
R-DRacing is going through a changeover in management and I guess their site is temporarily down.
Before I had the seat mount, I had fire extinguisher mount bolted to the floor in front of the drivers seat. That worked OK but the seat mount is better.
Old Sep 12, 2006 | 04:42 PM
steve haverl
got it, thanks.
To Fire Extinguisher Mount...
Old Sep 12, 2006 | 04:54 PM
Red Tornado's Avatar
Red Tornado
Originally Posted by hardlight
Halon puts the fire out right now.....Halon gas migrates to where the fire is, my experience is with aircraft fires.
except if there's any wind......then you can't put out the fire, and your car blows up.
i would NOT use halon.
Old Sep 26, 2006 | 08:22 AM
FF1wms's Avatar
FF1wms
Halon works good. It will put the fire out. : When released it will head for the flames removing the oxygen to smother the flames. If your not wearing some sort of breathing apparatus your going to want to hold your breath. Here's the little "glitch" in halon for close fire support, Once that Halon(refrigerant) contacts the flames it produces phosgene gas. Phosgene has been used as a chemical weapon over the years, as recent as the Iran/Iraq war when the Iranians gassed all those Iraq civilians with "Phosgene gas". That's some bad stuff, you really don't want to be in any confined space with it.
The ban on Halon didn't effect "critical use" industries. Military / Aircraft industry, among others, are exempt.
Old Sep 26, 2006 | 10:32 AM
Biff Buyer's Avatar
Biff Buyer
i was thinking about mounting one on the back of the passenger seat.
