Door guide replacement
Old Sep 1, 2006 | 11:53 AM
Huntervangolf's Avatar
Huntervangolf
Default Door guide replacement
I hate working on anything with the interior! Well after some cussing head scratching a couple of beers and one broken plastic molding around interior door handle my window works correctly The screw behind the door lock was what did me in. Still not sure how you get to that screw. If there is a trick let me know because I will have to figure it out when I replace the broken piece when I find one.
Old Sep 1, 2006 | 01:26 PM
Huntervangolf
Just looked at ecklers, they don't carry the door handle trim plate for 96.
Old Sep 1, 2006 | 02:09 PM
VetteUSA's Avatar
VetteUSA
St. Jude Donor '07
unlock the door, take a flathead screw driver and place it underneath the front part of the plastic door lock, use the screwdriver as leverage and that plastic piece should pop right off revealing the screw behind it.
To Door guide replacement
