I ordered my build sheet from the Museum and finally got it in. The only date on the form is Date: 92/114 Time: 01:28 , would that be the 114th day of 1992 (April 23) or the 114th day of building 1992s? I was hoping to find the born-on date and don't have it inside the hood like others have mentioned.
I suspect the date on the build sheet is the date the order was placed and the build sheet printed. My 1996 build sheet is a different format than your 1992. However the only date on my build sheet is in the top margin and it is 11/06/95 Time: 05: 15: 52
Go to your friendly GM dealer and ask them to use their TTY with your vin to run a "GM IVR WARRANTY HISTORY INGUIRY" If they will give you this report you will receive a record of all warranty work done on car and the production date, invoice date, and delivery date.
Mine stack up this way:
Date on build sheet: 11/06/95
Production Date: 12/04/95
Invoice Date: 12/13/95
Delivery Date: 07/25/96
That is the julian date so you had it right, january first is day 001 and december 31st is day 365 :cheers: just make sure your math is right and youll have the correct day
