D.I.Y. alignment ?
Front toe is very easy. with the wheel centered, I use some chalk and draw lines parallel to the tires with a straight edge on the garage floor, then measure the distance with a tape measure between the front and rear of the lines. Subtract the difference. This is the total toe. Adjust as necessary.
I've found that 1/4 turn on both tie rods equals about an 1/8" of total toe.
When I was about 1/8" toe out for the track, 1/2 turn in on both tie rods resulted in about 1/8" toe in (good for the street).
Then drive the car to check the steering wheel centering. With your hands off the wheel establish where the wheel centers itself. Don't be concerned with pull at this point, but of course drive with caution.
If the wheel centers itself offset to the left or right from center, simply toe the wheels in the same direction of the offset.
For example: If the wheel is offset slighly to the left, toe both wheels an equal amount (like 1/4 turn) to the left, so when the tires recenter dynamically they will pull the steering wheel back to the right toward center. Adjust as necessary. It is very easy requiring only a 13 mm wrench and 7/8" wrench to adjust toe.
Camber and caster is adjusted easily by adding or removing shims. 18 mm wrench or deep socket is required here. Jacking the car may improve access to the 18 mm nuts, but isn't always necessary.
What are you trying to adjust or correct in the car with a DIY alignment?
All you need is a toe setting. That would only be a couple of dollars at a small shop. It's not worth futzing around with it yourself...you might accidentally get it close, you'll never get it right.Larry
code5coupe
if you want it really right, use the equipment that all top racing teams use--strings and a level.
for toe, i use monofilament fishing line stretched between two 7 ft long 2x2 wooden studs on jackstands (one front, one rear)..the monofil can be stretched tight to get precision far better than any ''loser'' (oops-''laser'')...
for camber i use a 2 ft alum level with 1/4-20 adjustable ''feelers'' that stick out to contact the rim...feelers @ 16'' apart, 1* = 9/32''...for caster, measure camber with the wheels turned 20* left and 20* right and multiply the difference by 1.5 (caster affects driver feel and you may vary side to side to compensate for road ''crown'')
you get best results on a level surface...set tire press and load in car as you will be when driving...i use high-buck turntables--two 1/4 steel plates about a foot square with just a sprinkle of dry sand between on each side (don't lean on the car)
high-buck camber gauge (stuff bolted to the bottom is to repair the crack in that side)
Take your wrenches with you and go for a drive to check centering.
If the rod is round, you can turn it with pliers, or vice-grips, You may want to put a mark the tie rod for reference.
To get in the ballpark I use a set of jackstands and strings.
I use a magnetic camber/caster gauge.
I can get mine where I want it much better than most alignment shops.
An added bonus is when I'm finished, my steering wheel WILL be perfectly 'horizontal' on most roads and tires WILL wear evenly.
It's another fun thing to do similar to building and engine or applying another coat of Zaino.
