Speaker replacement goo
Old Sep 3, 2006 | 10:26 PM
vettecrazy88's Avatar
vettecrazy88
Default Speaker replacement goo
Replacing front speaker boxes (Bose) and don't know what the white goo that is used to seal them to the door is.
Anybody know?
Old Sep 3, 2006 | 10:56 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Why, you want to find more of it?
Window ribbon sealer will work. It's black and comes in a 15' roll, very gooey, tar like, and black. Check at pep boys.
Old Sep 3, 2006 | 11:00 PM
vettecrazy88
Thanks Central Coaster. Yes I would like to reinstall with it. I assume it either reduces rattle, or seals from water, or both. I'll check it out at Pep Boys.
Much obliged!!!
Old Sep 3, 2006 | 11:56 PM
Thrak's Avatar
Thrak
how did you get the boxes out? I've been struggling w/ mine...
Old Sep 4, 2006 | 12:46 AM
CentralCoaster
You have to remove the aluminum panel, after that its easy. Be careful putting the door back together. You have to get all the wiring harnesses in just the right spot to get the door panel back on.
Old Sep 4, 2006 | 08:36 AM
TripleBlack88's Avatar
TripleBlack88
Thrak,
Look at this site:
http://carstereohelp.com/strcorvette.htm
To Speaker replacement goo
