Door Lights
They should go off when you drive
Im still gonna go with the switch
If you pull the door towards you as you drive and it goes off Thats it
Also I started mine and with the door open pushed the switch down
In the later years they were self adjusting The center part came out further
If it is sitting flush Its bad
Replacing can be a PITA cause the part the screws go into is not attached and can fall into the door if it comes offf the pigtail
The FSM says to get a long screw to hold it down
Take one out and get about 1.5 in long to hold it while you take the other one out Just dont shut the door
Home depot is your friend
Other than that not a difficult install
