Clutch Question
Old Sep 6, 2006 | 07:13 PM
jserio's Avatar
jserio
O.C.
Default Clutch Question
I am curious about my clutch. The gears do not catch until the the clutch is on the high side of the pedal. Now the car just rockets with no problem at all, every gear, anytime. No slipage what so ever. Would you say this clutch is on its way out or could a good bleeding deminish some of this problem? Unfortunately I am pretty recent with owning an american stick so I do not really know how to tell. Sean at OC Corvettes said it was on it's way out but really did not look into anything else first. I figure he would know but I am double checking.
IF....... The clutch can be blead then how do you do this?
Joe
Old Sep 6, 2006 | 07:54 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
I have a new clutch kit and it starts engaging with about 4 inches of pedal remaining. I'm not sure I understand your terminology but it sounds O. K.
Old Sep 6, 2006 | 08:25 PM
aminnich's Avatar
aminnich
Bleeding would not be likely to help any, and the clutch itself is not adjustable. There might be a linkage adjustment, but it really sounds like the clutch disc wear is near the end of it's service life.
Old Sep 6, 2006 | 08:28 PM
STL94LT1's Avatar
STL94LT1
My 94 does the same thing, has done so since I bought it new in July of 1994.
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I agree. Just start saving some money for the day when....
Old Sep 7, 2006 | 03:10 AM
jserio's Avatar
jserio
O.C.
I just bought a Centerline stage 1 plate and disc a few weeks ago as to not take a full blow when it's time.
As far as my interpretation of the "throw" with the pedal. Let's say from the floor to where the pedal stops is 100%. Then it is not catching until 75 - 80% to the top.
Thanks for the feedback. It is most appreciated. BTW, When a clutch really starts to go will it leave me stuck or will I know when it is time like immediately.
Joe
To Clutch Question
