Brake Bleeding Kit
Old Sep 6, 2006 | 07:31 PM
timbuddy's Avatar
timbuddy
Default Brake Bleeding Kit
Who makes a good Brake Bleeding Kit for the c4, that can also be used on a c2 as well.
Thank-you.
Old Sep 6, 2006 | 09:36 PM
mhayes's Avatar
mhayes
I just did the conversion to C5 brakes last weekend. I used a MightyVac vacuum bleeder (the metal unit). Worked very well. Makes it a one man job. There are plenty of adators to allow it to work on any vehicle. Don't forget the prime pipe bleeder on the ABS unit!
Mark
Old Sep 6, 2006 | 09:42 PM
Redvette_22's Avatar
Redvette_22
Thank-you.
My buddy and I purchased a unit to use on our C-5's and it fits the C-4 as well. It is a pressure unit that works similar to the dealers unit and it only cost about $60 with the shipping. If your interested I can get the name and you can get it on-line, like we did.
Old Sep 6, 2006 | 10:48 PM
Gary04Z06's Avatar
Gary04Z06
I just order the Motive bleeder, check out this thread:
http://forums.corvetteforum.com/show....php?t=1485905
They have different ones, one comes with several caps to fit most any master cylinder.
Old Sep 7, 2006 | 12:15 AM
Great White North's Avatar
Great White North
My Mighty Vac works good for brakes but sucks on the clutch so I got a Phoenix bleeder coming!!!
Old Sep 7, 2006 | 03:43 AM
SSLT1KID's Avatar
SSLT1KID
i have a bleeder from harbor freight. works fine for me.
Old Sep 7, 2006 | 08:06 AM
runner140*'s Avatar
runner140*
Several years ago i purchased a set (4) speed bleeders. Your going to be doing this (bleeding) at least once a year, do yourself a favor and buy a set of speed bleeders.
Old Sep 7, 2006 | 08:48 AM
tlong's Avatar
tlong
Motiv Power Bleeder. Blows, doesn't suck.
Old Sep 7, 2006 | 09:16 AM
kehler's Avatar
kehler
Old Sep 7, 2006 | 10:24 AM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
My buddy and I just use the cheap bleeder from Autozone or wherever. the little squeeze bottle with the magnet on it and the hose attachment.
It works on all cars, even my C4.
Old Sep 7, 2006 | 09:01 PM
timbuddy's Avatar
timbuddy
Thank you all for the input. Think I will buy the Motive Pro for $79.00This way my other corvette buddies can utilize it as well.
cheers
Old Sep 7, 2006 | 10:56 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
I bought the Mighty Vac with all the different adapters, & tried to bleed the brakes on my `94 Dakota 4x4--- --- finaly had the wife pump the brakes, while I bled them. That Mighty Crap went in the trash. Glad I diden`t try to bleed the Vette`s brakes with that thing.
Old Sep 8, 2006 | 10:18 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
I've tried vacuum bleeding brakes on several cars...but with little success. I've used the Mity-Vac and an electric vacuum pump, neither worked well. I've since gotten a pressure system that should do the job.
Post up the link, red98C5!!!! i want to see this!
Larry
code5coupe
To Brake Bleeding Kit
