need Help stuck throttle?
Old Sep 7, 2006 | 12:55 PM
ittybittyfds's Avatar
ittybittyfds
Default need Help stuck throttle?
I drove in to work today and everything was fine
went to go out for lunch and noticed my throttle felt high in nutral
put her in gear and the throttle dropped
again push clutch in and let her out and idle is high again
any ideas
so sitting in nutreal its at a fast idle
Old Sep 7, 2006 | 12:56 PM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
Lift your foot
Sounds like a throttle return spring
Old Sep 7, 2006 | 01:04 PM
ittybittyfds
the idel seems to be getting higher as it sits
Old Sep 7, 2006 | 01:31 PM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
Check the return spring on the throttle. I broke one in the middle of a race once. I pulled into the parking area and the thing was idling at like 5G's heh. Needle nose and some rigging fixed it right up. I replaced it later on with a stiffer spring so I wouldn't have such a heavy foot
Old Sep 7, 2006 | 03:15 PM
ittybittyfds
well its not the return spring. and i dont hear any vacume leaks
Old Sep 8, 2006 | 07:22 AM
ittybittyfds
boy did it crash hard
i had to drive home but needed gas so i filled her up.
wouldn't start after that. 15 minutes later i tried to start her again and it finally started. so i drove her home. on the way the Check Engine light comes on. Then my Oil pressure shoots up to 68 usually never went higher then 63
anybody know were to get a code reader so i can check the check engine and see whats its reporting
To need Help stuck throttle?
