Steering wheel loose
Old Sep 9, 2006 | 12:42 AM
golfpro77's Avatar
golfpro77
Default Steering wheel loose
Has anyone ever been able to fix a loose sterring wheel... mine is a little loose & I have replace the bearings, tilt cams, tilt springs ect. Not the column mount bolts.
Any ideas... or what have you all been successful at fixing this problem.
Old Sep 9, 2006 | 08:48 AM
87vette's Avatar
87vette
Are you referring to the column being loose ? If so I just found out it wasn't the 4 bolts that hold the column to the steering housing. My steering housing is whats gone bad and became worn. I'm going to hold out on this job for another time since I had the thing apart 2 to 3 times already.
Old Sep 9, 2006 | 09:31 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Yes, they have, and it depends on what...exactly...is loose.
Need more details...
Larry
code5coupe
Old Sep 10, 2006 | 06:55 PM
golfpro77's Avatar
golfpro77
Default Loose
i have also had it apart about 5 times over the last few years: here is what I have replaced:
Tilt pins (2)
Tilt adjustment cams
Tilt Spring
Tilt Lock spring
Upper column bearings
The actual column is not loose, it seems to be the upper tilt part of the column... where the steering wheel is attached. My 1st tought was it was the tilt pins because it seems to be only loose from that point on. But it was not the case. It seems like a wear problem as it only is loose a little and replacing the above parts helped but it is still about 1/2" loose ... I mean it moves side to side if pulled harder.
I hope this might give you all more ideas. I have heard that they become loose from holding the steering wheel to get in & out of the vehicle over time?
Old Sep 10, 2006 | 07:14 PM
rocco16's Avatar
rocco16
Hmmmm...it seems to me that, having had it apart that many times and doing that much maintenance on it, you'd be an expert on the workings of the column. Man, if YOU can't figure it out, what chance do we have??
My experience, compared to yours, is minimal and I wish I could offer some advice, but it looks like you have covered all the bases but one; the one that is giving you all that movement.
Good luck. Seriously. I can't be of much help...
Larry
code5coupe
Old Sep 10, 2006 | 08:18 PM
AILERON's Avatar
AILERON
Are you talking about being able to pull it to the left and down?
Old Sep 13, 2006 | 10:42 PM
golfpro77's Avatar
golfpro77
Default yes yes yes
YES that is primarily the way it will go... What are you thinking?
Old Sep 13, 2006 | 11:58 PM
MrRenoman's Avatar
MrRenoman
Might be the plastic universal type joint, also known as the sphere, that joins the upper shaft to the lower shaft...
Art
To Steering wheel loose
