broken console cover..
Old Sep 13, 2006 | 07:43 AM
Arlon's Avatar
Arlon
Default broken console cover..
My console cover had one too many elbows pushed down on it and it was cracked all to pieces. I took it off, fiberglassed it from the inside and now you could probably park a truck on it. It had to be the fastest surest cure for a cracked cover going. One side door panel was also cracked pretty bad. It got the same glass treatment. I cleaned the plastic really well and used epoxy resin (not polyester) and it seems to stick very well to the plastic and rigidity is 10X what it was.
